Question about Hitachi Saws
Need new handle for chop saw - Hitachi Saws
  • 396 Answers
Try eRelpacementParts.com and select you model of saw.
http://www.ereplacementparts.com/hitachi-cutoff-saw-parts-c-7927_13236.html
Posted on Mar 15, 2011
Steps to operating the Ryobi chop saw.how do you unlock it
Push down on the handle, a spring load pin should move out. Mine is on the left side where it hinges. Lube it if it doesn't move easily.
Jul 16, 2017 | Ryobi Saws
Cannot get saw to lift up on toedo chop saw
If your handle has two buttons, they are usually a power swtich and safety button so the saw isn't accidently started. No, power should not matter in the function of the swing arm. Most chop saws lock down by way of a small chain from the base to the end of the handle. Most miter saws and some chop saws lock down by way of a pin located on the pivot point of the swing arm. The pin locks the swing arm down by passing through a hole in the base pivot bearing.
Aug 17, 2012 | Saws
Replace switch on chop saw
unplug tool, remove the top of the handle assembly, either take a picture or write yourself a wiring schematic before removing anything, I would suggest taking a photo so you know where the safety device goes and the wiring, loosen the screws and remove and replace the switch.
Oct 01, 2011 | Makita 10" Miter Saw LS1030N
How do u get the handle of the chop saw to lift up
usually there will be a locking knob on the side of the blade handle. if you cant locate, send me model # and brand.
Thanks
May 20, 2011 | Garden
Handle for chop saw
You did not place a make or model number here...
Here is a website that has many parts for many different tools...
heatman101
Mar 15, 2011 | Hitachi Saws
6180-20 chop saw trips 20 amp on start up all the time Terry
If it trips the breaker as soon as you hit the switch, check the power circuit. Check the power cord for frays or cuts, especially where the cord goes into the saw. Remove/split the handle and check the wires into and out of the switch and to the brushes and field. Lood for burned or melted wires or case parts. Milwaukee is notorious for running lots of small wires in very tight places. Make sure none of them got pinched when the tool was assembled. Watch for this also when you reassemble the saw. Check the brushes, if they're worn or broke they can cause a short on the armature. If these all check out you need to have the armature checked on a growler for shorts.
If the saw runs for a few seconds then trips the breaker I'd check for gear and bearing problems. Cehck for free, smooth movement of the bearings on the armature and blade drive assembly. The blade should turn freely by hand. Feel for undue resistance or a gritty feel in the bearings and gears. If necessary replace any offending parts.
Aug 31, 2010 | Milwaukee 6180-20 14" Chop Saw Abrasive...
Metal chop saw blows breaker
Is there anything else running while you are cutting? If not is the breaker 15 amp or 20 amp. If its 15 amp, I would change it to a 20 amp breaker. Make sure the wires are thick enough to handle the extra load. If this isn't the problem check the cord from the saw to the outlet.
Good luck!!
Jul 28, 2009 | Dewalt Chop Saw D28700
My wilton chop saw motor appearsto be dead
take it to a electric motor shop and talk to them if they tell you a price way out the cost of new saw verces the amount of new motor.If it is half the cost of new saw or lower I would have the repair shop replace it or buy the motor from them and repair it myself.
Feb 02, 2009 | Wmh Tool Group Wilton 99174 14" Abrasive...
Saws Logo
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
