Question about Stihl Chain Saw Handle Models 064 066 Ms640 Ms660
Blown up stihl 064 having trouble getting replacement cylinder.Can I put a 066 cylinder kit onto this saw. Cheers Rohan
  • retro72 Mar 16, 2011
    cheers mate all I can do is try it.Thanks Rohan
3 Suggested Answers
barterjoe
  • 344 Answers
SOURCE: keep burning up piston on
It sounds like you are running lean. Not a lean oil/gas mix but a lean Air/fuel ratio. This engine runs hot as a high performance engine. any air leaks such as crank seals, manifold gaskets or muffler gaskets can give you too much air for the fuel coming in.
Secondly from the fuel side:
Ethanol (curse it) combines with oils that have no nondispersants making a white chalky poweder in the fuel system causing less fuel to mix with air. any blockage or pin hole leak can cause less fuel to be brought into the engine thus less cooling and lubricating.
Your carburetor and fuel filter need to be serviced and adjusted correctly or they will affect the mix.
When done the engine should run no faster than 13,000 rpm top no load speed.
This engine should idle smoothly at 2,500 with no more than 150 rpm change
if the speed is not as listed above when the rebuild is done you need to go back into the machine.
Call up a shop like www.arcolawn.comto get a EDT8 tach. it is well worth the money.
good luck
Joe
Posted on Feb 12, 2011
philwalker78
  • 608 Answers
SOURCE: stihl 066 leaks gas out bottom of carb
Hi, you have a hole in the pump diaphragm in the bottom if the carby. Regards Phil.
Posted on Jul 10, 2012
Is my stihl chainsaw an 066 or 064
The O66 and O64 are basically the same saw just with a different bar option. All of the parts are interchangeable. If you need parts the serial number is what you will refer to. Also taking your saw with you to the parts store is always recommended.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Jul 16, 2016 | Stihl Garden
Will a 56mm cylinder kit fit a 064
http://sawparts.ca/products/stihl-064-066-ms650-ms660-big-bore-cylinder-kit-nikasil-56mm
It seems that YES a 56mm aftermarket cylinder is available for the Stihl 064. Looking at the kit you need to just replace Cylinder, Piston and rings, bearing bush and clips. Worth also replacing the base gasket too.
May 01, 2016 | Stihl Models 064, 066, Ms640, Ms660
Does a stihl 064 flywheel fit an old stihl red eye 066
What's a red eye? If the first four numbers from the old flywheel match up with the ones on the replacement, they should swap. I'd suggest just getting the correct one instead of trying to jerry-rig a chainsaw. eBay is a great resource for used parts and they're usually fairly cheap.
Oct 23, 2012 | Stihl Garden
Sthil 066 carb diagram
Don't mess with the insides of a STIHL carb, just buy a new one. Why put new parts in an old carb?
Jan 18, 2012 | Stihl Models 064, 066, Ms640, Ms660
Sthil 066 chainsaw
You are absolutely right, an 066 is a STIHL model chainsaw. Good job!
Looking for a parts diagram for a stihl 066 chainsaw
The one with the two right angle connectors is the inlet line. The other is the return line
Nov 05, 2011 | Stihl Models 064, 066, Ms640, Ms660
Parts diagram
You don't get to have one, you're not a professionally trained STIHL tech.
Oct 02, 2011 | Stihl Models 064, 066, Ms640, Ms660
Stihl Chain Saw Handle  Models 064 066 Ms640 Ms660 Logo
260 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
