Question about Briggs & Stratton Garden
I have a model 760-770 mower it started running real ruff now i cant get it to crank i changed spark plug and drained gas and carb to see if water was in it its getting gas to carb i took the filter cover off and tried to crank it it spitting out alot of gas and kinda pops when i choke it but it still wont start
  • 784 Answers
Hawe you checked safety switch`s?
Posted on Mar 15, 2011
Lawn mower instructions why wont it work
check for spark at plug if spark at plug then squirt some starting starting fluid in carb see if will start it should run long enough to burn out starting fluid if does check for water in gas if is drain tank and carb bowl put in fresh gas not and repeat not old gas you were using strat lawn mower if still dosnt start rebuild carb and add and additive called seafoam to the gas this is good stuff follow instrution on bottle
Sep 02, 2014 | Garden
Mower will not start after changing the battery out and checking all connectioncs
U could try to use some starting fluid spray into carb and have someone crank it right away But first do you have fresh gas in the tractor if not I would drain and fill tank with fresh gas. Also I always change my spark plugs at the beginning of the season,
Apr 10, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Motor mower wont start
By tipping a 4 cycle motor on a lawn mower or any equipment, you have all the oil and gas running into the combustion chamber and sometimes the oil and WATER will get into the tank. It will need too have the spark plug removed, the engine turned over with the starter to blow the oill, gas, and water out of the cylinder(s), the plug should be either dried and gap reset, and the gas tank drained and FRESH gas put in it. Replace the spark plug prime with just a few drops of gasoline in the carburetor throat and restart and let run to dry evrything. NOTE: An oil change is recommended, too!!
Jan 14, 2014 | Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Start and ran the mower for 10 min Shut it down and now can't get it running for more than 10 sec. Changed the gas drain the old gas Changed the spark plug, cleaned the filter as stated. still can
Tecumseh engine right? Pull the float bowl off the carb. I suspect some water contamination. while it is off clean the jet holes in the nut. They may have varnisized gas in them. contact me with any more questions.
Sep 13, 2012 | Yard Machines Garden
190cc 675 sears push LM. Irene put it under water. Drained carb and crank. removed and cleaned filter. New gas. Won't start. Got a little pop with starter spray. No pop at all?
Did you drain fuel tank before refilling with fresh fuel? Drained carburator bowl good, drained crankcase and refilled with fresh oil good,removed air cleaner and dried out good. One question for you , did you remove spark plug and drain any water that may have gotten into your cylinder through an open valve? There could be water sloshing around in the cylinder, gas and water will not fire, and water on spark plug wont allow plug to spark. If you need any more help please get back to me , I believe this is the first under water problem I've encountered. GOOD LUCK.
Sep 07, 2011 | Briggs & Stratton 190cc 875 Series OHV...
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
144 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
