Question about Cameras
Canon sd 1000
Hi My canon SD 1000 stopped working today. I am able to see all the pictures on my memory card but when I switch to camera mode to take pictures i see blank, nothing!!!!!
I am sure the display is working but i am afraid that the lens is gone!!!!!
  • 33 Answers
Hello!
Are you able to see white icons around the edges of the screen while in "camera (auto) mode" and the rest is black? If so, this is just as simple as pressing the "Disp" (display) button to remedy this.
Posted on Aug 01, 2008
  • 477 Answers
Does it give you a lens error? are the shutter closed?
It is either the lens or the CCD.
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Card locked
If your camera uses a SD memory card then -
SD and Mini SD memory cards SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Feb 02, 2013 | Canon PowerShot SD600 Digital Camera
Canon powershot sd 1000, memory card not detected
Please try to copy all the contents of your SD card to your computer. Then format the SD card and try it again on your camera.
If it still can't be detected, try another SD card.
Aug 08, 2012 | Canon Cameras
My memory card in my canon camera suddenly won't let me take or delete pictures because it says card locked. - have been using it without a problem but then today it suddenly said "card...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards.If youare getting a memory card locked message then check this out.
How to UnlockSD Cardheatman101
Aug 04, 2011 | Cameras
My Canon EOS camera was working fine. Now that I want to take pictures it say card write protection. How can I fix the came so I can take pictures?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try another card.
May 16, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Hi, I have Canon IXY Digital PC1101, showing error for 4GB SD Memory, where as the same is working in laptop. If i put 256MB SD in camera it's working.. do i need to do any firmware upgrade to camera to...
The PC1101 uses SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. Since this is a hardware incompatibility, no amount of firmware changes will make it work. You need to stay with SD cards, 2GB and smaller.
Jan 05, 2011 | Canon IXY 1000 Digital Camera
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Jul 10, 2010 | Fuji FinePix S8100fd Digital Camera
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon SD1200 IS won't save pictures to the memory card.
This Canon uses an SD memory card (previous Canon used CF cards).
The SD memory card has a "slide switch" that locks the card.
Look at the SD memory card and move the switch back and forth, then switch it all the way to the UNLOCK position. Put back in the camera and format the card, then use it.
Since this is a 10Megapixel camera, use at least a 2GB SD memory card. A 2GB SD card will hold 700 pictures, or so, in the best setting.
Hope this helps!
Sep 03, 2009 | Nikon COOLPIX S60 Digital Camera
Unprotect memory card
To set the memory card in unprotected mode, you have to do the following.
On the side of the SD chip, there is a little switch. Shift the switch away from "lock", then insert the card back into the camera.
This unprotects the card. You should now be able to take pictures and videos.
If this does not solve the problem, then it is very likely that the SD card is faulty. I would recommend using Panasonic, Lexar or Sandisk memory cards.
~Lexar SD card
~1 Panasonic SD card
~2 Panasonic SD card
~Sandisk SD card
Jul 13, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Cameras Logo
74 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
