Question about Bose Companion 3 Computer Speakers
I have a Bose outside speaker that has quit working. It is the speaker, not the wire. What could be wrong?
  • 27,725 Answers
Try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Mar 15, 2011
How to open a BOSE 161?
Yes, the grill can be removed. To pull out the grill you need to clamp on the sides but inside between the outside of the mesh and the outside part of the main plastic housing. pry at least a one incu on both sides, clamp it and wiggle it up until it pulls out. to reomve the speak is more work, on the center of each side, you will want to use a 1/4" screwdriver, but nice and thick. slide it on the center of one fo the sides of the speaker downward. looking downward on it, you will see two dimples with the center opened. slide the screwdriver between the dimples at least 1/4" down and thenbend outward slightlight the scredriver so it can grab on to the opening underneath the dimples., keep doing this on all four sides until it is loose enough for you to wiggle it our by hand. do note, that the wires inside are real short, to remove the speakers completely you will need to unwind the wiring attached. the wire is solid not mesh, so you will need to use a tweezer of sort or micro screwdriver(such as for glasses) to loosen the wires. once that is done, you can pull out the speakers a swell as other components. remember, the wires inside are real short. not long enough to disconnect them, a little work is needed to disconnect the wires.
Jun 15, 2012 | Bose 161 Rear Speaker
Bose free space 51 speaker pair. 1 speaker stopped working. I disconnected non working speaker and hooked up at the working speaker wire and it still didn't work. don't know how to take it apart to...
In my case the speaker only played the higher frequencies but not the low mid range to base. Most likely your speaker is "blown". Outdoor use is hard on electrical components. The fix is easy. The free space 51 speaker is identical in size to the standard Bose 901 4 1/2" speaker. You can buy a Bose or a good quality knock off (either way they will need to be broken in before yielding the best sound). It is not clear to me whether the original Bose uses a special moisture resistant cone. I treated my replacement with a light coating of silicone spray (for upholstery) carefully protecting the foam surround and cap at the center.
Just unscrew the three screws holding in the plastic grill in front of the speaker (using a nut driver or socket wrench). The speaker will drop out. Be careful with the foam wrap around the wire as it tends to be fragile and greasy. Solder in the new speaker making sure you get the polarity right (although for outside use this is probably irrelevant). I would test the speaker in place before soldering just to make sure. Reassemble and break in the speaker. Again I don\'t know know well the replacement will weather the elements. Keep your finger crossed.
Jul 23, 2011 | Bose Free Space 51 Main / Stereo Speaker
I have bose speakers connected to a sony receiver and I want to chance the sony receiver to a bose receiver without changing the wires on the speakers. The sony receiver was old and has stopped working. ...
Hi.
Even though you may need to put new plugs on the ends of the wire, you can still use the wires without having to go out and by new.
Places like Radio Shack, Fry's, Ovation, BestBuy, and CompUSA all carry wire plugs that you can install yourself rather easily on the old wires to make them work with the Bose receiver.
Putting plugs on the ends of the wires is really a simple thing to do.
Just follow the instruction that comes on the pack, and you should be fine.
I don't blame you for wanting to utilize the old wire, it can get expensive to replace speaker wires.
The plugs are a cheap way of saving wire, and saves you quite a good deal of money as well.
I hope this helps you out, and good luck !
Jun 07, 2011 | Bose Cinemate Digital Home Theater System...
The sound coming from my right bose on-ear headphones
i think ur headphone wires or its pin at end will be defective..
99%there is no chance of failures in speakers ..
try to replace ur headphone cable with new cable.
just solder the cable with speaker inline pins..
May 25, 2010 | Bose On-Ear Headphones
Bose surrond sound not working...
Your TV may have a setting to make its Audio Output Variable or Fixed. That is, as you turn the TV's volume down or up it will either vary the output (as it seems to be doing in your case) or keep it Fixed so external electronics can still use it when the TV's volume is down or off. Some TV's do it another way - they have a selection to turn the TV's speakers OFF.
Feb 03, 2010 | Bose Cinemate Digital Home Theater System...
No surround sound
It sounds like the speaker wires are mixed up or maybe a setting on the reciever is wrong. Verify your speakers are properly connected. you test speakers using a 9 volt battery or smaller.
Jun 19, 2009 | Bose Lifestyle 12 System
Outside bose speakers keep turning off after a few seconds
It sounds like the speakers are either peaking and shutting down or they are dodgy. Check the volume going into the speakers and turn it down see if that works, otherwise take the speakers back. It might be worth trying a different set of speakers as well
May 24, 2009 | Bose Lifestyle V30 Home Theater System -...
Lifestyle 30. sound stops, i unplug and plug back in and works for short time and quits. unpllug and plug back and works a short time and quits.
What you describe, sounds like a speaker short. Are you using the Bose wiring with their ends and no cuts in the wire? (splices) It's not too uncommon to extend or shorten a wire. The fastest way to find a short is to disconnect your speakers at the speaker. Be careful to keep the wires separate if they are not on plugs and turn on. If it cuts off (power) or says (protection) on the display that lets you know your speakers are ok and you have a short in the system or a wire. Next, disconnect wires at the sub one by one and test until it causes the system to cut off or short. Leave that speaker disconnected from the sub and test with all others connected. Now you've located the channel that has the problem. First just connect the wire again to the sub. if it cuts out, run a new wire from the sub to the spkr, for testing purposes make it a short wire if possible and test. If you need to use a Bose plug at the sub to test spkrs go buy one at Bose, don't cut your factory wire just yet. If a new plug works then cut and replace. Make sure you use electrical tape not scotch tape or duct tape. If it works fine, test the new plug on the old wire and see if it works. If it does your done, if it doesn't, run a new wire to the speaker with the new plug on it. If after all this and it still doesn't work. Sounds confusing I know, It's just process of elimination, that's how we do it in the field. If all your speakers are disconnected and it still cuts out, it could be the sub or the receiver. Take it to a Bose store and they can check each piece for functionality. If it needs repaired let Bose do it. Hope this helps.
May 10, 2009 | Bose Lifestyle 28 System
No volume
The Bose system in the Z is wired to control the entire car's speakers. Each speaker has its own amplifier, and the OEM head unit puts out a line-level signal to each amp. Your Clarion unit puts out speaker-level signal (in effect, an amplified signal), into the Bose amps, and it's probably overdriving them and putting them into shutdown.
Your best bet is to replace the Bose speakers with aftermarket speakers meant for a speaker-level drive (which is what I did in my Z, and never once regretted it). If you do so, you'll need to run new wires to the speakers, or if you use the OEM wiring, you'll need to unplug the amps and run the wires from the amp harnesses directly to the new speakers. I think there is an adapter harness you can use that will tap into the line-out jacks on your Clarion, so that a line-level signal can be sent to the Bose speakers - I'd do a google search for "Metra harness 300zx" or something along those lines (Metra makes the lineout harness adapters - I use one in my Audi).
Sep 16, 2008 | Clarion DXZ755MC CD Player
Bose Companion 3 Computer Speakers Logo
32 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
