I have a DIGILOGIC DSTB 1000.free-view box. Every thing else is working fine but the box is vey slow in responding to the remote control.It has been like this since new.I've tried numerous new batteries and checked all the leads & cables but nothing seems to make any difference. ALTO
5 Suggested Answers
Erik Seattle
SOURCE: My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
Posted on Apr 28, 2009
SOURCE: LG LCD TV won't respond to remote controllers
sparrow00, your fix worked for me, and I think I know why. The 1/8" remote input jack on the back of the TV has electrical contacts inside that are probably there to sense the presence of a plug-in remote. When they detect the insertion of this plug they disable the front panel IR (infrared) receiver and the TV only responds to this plugged-in remote and the buttons on the TV itself. After some period of time these contacts get corroded and the circuit is no longer completed between them. The TV now thinks an external remote is plugged in, and it ignores its own front panel IR receiver.
When you plug a 1/8" plug into this remote socket on the back of the TV it wipes away the corrosion. When you remove the plug the internal contacts conduct properly again and the TV responds to its front panel IR receiver. For best results you should plug a 1/8" headphone plug into this remote jack and twist it a few times, then pull it out and repeat several times. Repeat every frew months or whenever the TV acts up.
Thanks for your solution!
Posted on Sep 01, 2010
budmrtn
  • 11361 Answers
SOURCE: No light on my Digilogic
It uses switchung power supply inside, so are you getting any 5vdc and 12vdc from the power supply outputs/ No bad caps found inside? Post the pictures if you can.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Dec 30, 2010
walesarumi
  • 6993 Answers
SOURCE: The TV will not respond to the remote and
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
You need to do some diagnosis to confirm the source of the problem.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Posted on Nov 28, 2011
Hi cAn anyone tell me the code on universal remote control for my digilogic freeview box DSTB 2000 inc a pic
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Apr 14, 2014 | Televison & Video
Tip
Digilogic DVDVCR2 Region Free Code Would you like your Digilogic DVDVCR2 to be...
Would you like your Digilogic DVDVCR2 to be region-free and play all DVDs? Here are the steps to make your Digilogic DVDVCR2 region free:
  1. Press the Standby button on your remote control to place the unit into Standby
  2. Press the Standby button on your remote control to turn on the unit
  3. Press the Open/Close button on your remote control to open the drive tray
  4. Press the Clear button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 3 button on your remote control
  7. Press the 6 button on your remote control
  8. Press the 9 button on your remote control
  9. Press the 0 button on your remote control
  10. Press the Open/Close button on your remote control to close the drive tray
  11. Press the Standby button on your remote control to place the unit into Standby
  12. Press the Standby button on your remote control to turn on the unit
Your DVD / VCR combo is now region free.
__________________________
Is your Digilogic DVDVCR2 locked in SAFE mode? View my other Digilogic tip to unlock SAFE mode.
on Apr 07, 2010 | Televison & Video
Signalex remote codes for digilogic freeview box
038,033,032,036. Try these codes. If you wish to get more codes and other details check:
http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 03, 2014 | Televison & Video
DI need help with my digilogic DSTB1000 free view box Ineed the code for my new remote can you help
try (2)0030 my remote requires the 2 before the code. Yours might be different, Not 100% sure
Nov 25, 2011 | Televison & Video
My remote control is not working how to install a remote application for life view tv card.
I have the same problem. It was working fine until today when i tried to switch a channel, i realized that the remote control was not responding. The funny thing is that using ubuntu and tvtime it works!
Jan 26, 2010 | LifeView FlyVideo 2000 / FM (701013821030)...
Digilogic free view box will not switch on just get red light on
HELLO
Before writing off the freeview box, have you changed the batteries in the remote control? The batteries you get with these units are questionable and they are usually rubbish quality anyway. If you have then it may be a remote problem - check the battery contacts - have the batteries leaked or corroded the contacts in any way?
If all is well, try putting the remote next to a radio with medium wave or long wave on (any AM radio will do). Press the power button on the remote and tune through the radio while doing it - you should hear a pulsing noise.
If the remote is OK then it is certain that your freeview box has gone down and a new one will be needed. I know this reply is long-winded but you would be surprised the amount of times things point back to the remote and not the box. Always try the obvious first!
Hope this helps!
Sep 01, 2009 | Digi Televison & Video
Digilogic tv receiver - child lock
how do i get ma channels back on my echostar digi box
Jun 27, 2008 | Televison & Video
How do I set up a Free-to-View digital TV receiver (DSTB 1500)?
I used the internet to look at the instructions for my TV and the instructions for my freeview set-top box. Thanks for asking but I know how to do it now.
Terry
Mar 12, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
