Question about Car Audio & Video
How do I remove a factory installed radio from my Honda Civic R reg?
    Problem Solver:
  • 4 Answers
Take the dash off to where you can get to the radio, then unplug it. and i recommend that if you are going to put in a new radio. get a wiring adapter for you car model from walmart or a system shop, they keep you from cutting and splicing your wires, i did the same to an alero and a civic for a couple friends...
Posted on Aug 03, 2008
Radio security on 1999 honda accord
my guess.
it the radio pass word is lost.? right?
if radio is stock, only the dealer can fix this. ask them and take reg. and photo id.
Oct 31, 2013 | 1998 Honda Civic
Tip
Honda Civic 2004 radio removal
See this video https://www.youtube.com/watch?v=GxZDgcon_YA Honda Civic 2004 radio removal
on Jul 07, 2014 | Honda 2004 Civic Radio
Tip
Reset the Radio on your 2001-2005 Honda Civic
If the radio on your 2001-2005 Honda Civic (as well as some other Honda products) has lost power for any reason (i.e. dead battery, blown fuse, etc), you will need to enter the reset code.
The reset code for the factory installed radio is located in the glove box. Open the compartment; On the back of the door, usually near the left side, there should be a small white sticker. The sticker has one alph-numeric set and one set containing five numeric digits. The number set with five digits is the reset code for your factory installed radio.
Turn on the radio. When you see "CODE", use the corresponding station pre-set buttons to enter the code. If entered correctly, the radio should active immediately.
on Jul 29, 2010 | Honda Civic Cars & Trucks
El radio de mi carro honda civic ex 2001 esta bloqueado como puedo desbloquearlo
Regístrate en Honda Vincular propietarios en el enlace que he proporcionado. Con el número de VIN de tu Civic que le proporcionará el código para desbloquear la radio. Para poder insertar el código que debe desbloquear la radio. Para desbloquear la radio, encender la radio durante 1 hora y que desbloquear y permitir que introduzca el código.
https://www.ahm-ownerlink.com/login.asp?page=%2Fprod%5Fhome%2Easp
Jan 07, 2011 | 2001 Honda Civic
Need factory radio code for 93 honda civic...dont have serial#
you will need to contact the dealer. You will need your VIN # and the serial number off the back of the stereo. Without these 2 numbers it will be difficult to get the factory code. You can however remove that unit and get a new unit installed from just about anywhere. Radio and installation should be under 150 installed correctly.
Aug 13, 2010 | Honda Vehicle Parts & Accessories
Volume on honda civic radio not working
atxhonda is right. Your going to have to replace the stereo and an aft mkt stereo will be the cheapest by far, however you should know that 96-00 Civics keyless entry control unit is inside the factory unit and by replacing it with an aftermarket deck you will lose you factory keyless entry system. If you don't have or use honda factory keyless entry or maybe you have an aft mkt keyless entry installed than I would go with the aft mkt deck.
Dec 06, 2009 | 1997 Honda Civic
Replace a starter
1999 Honda Civic DX 1.6L MFI SOHC 4cyl
Starter Removal & Installation
Fig. Starter wire connections
Fig. A ratchet and long extension may be needed to remove the starter
The factory sound system has a coded theft protection system. It is recommended that you know your reset code before you begin.
  1. Disconnect the negative battery cable.
  2. Remove all wiring from harness.
  3. Remove the lower radiator hose from the bracket on the starter motor.
  4. Remove the starter cable from terminal B located on the back of the solenoid.
  5. Remove the black/white wire from the S (solenoid) terminal.
  6. Remove the two bolts that mount the starter to the transaxle assembly.
  7. Remove the starter.
To install:
  1. Install in the reverse order of removal.
When installing the heavy gauge starter cable, make sure the crimped side of the terminal end is facing out.
  1. Enter the anti-theft code and radio presets.
I hope help you with this (rated this help). Good luck.
Sep 09, 2009 | 1998 Honda Civic
1997 Honda Civic EX Keyless entry programming
If you still have the factory radio, there is a way to split the power wire for the factory radio to the aftermarket radio. All you will need are the power and ground for your aftermarket radio, so the rest of the wires should be untouched on the plug for the factory radio. You can simply re-install the radio within the dash and retain the keyless entry as well as restoring your dome light function. Here's a PDF of some instructions. If you did not keep the radio, I would suggest looking online or ins ome junk yards, because it is needed. www.installdr.com/InstallDocs/Honda/PDF/466013.pdf
Jan 08, 2009 | 1998 Honda Civic
Program a fob for a 1996 honda civic ex
If you still have the factory keyless entry for your civic, the stock radio is still located within the car. Most likely it is located behind the center console. There is a button on the radio between the AM/FM and CD buttons. Turn the ignition on without starting the car, hold the button down and push any button on the fob to program the fob.
Dec 07, 2008 | 1996 Honda Civic
Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
Aug 08, 2008 | 2002 Honda Civic
Car Audio & Video Logo
113 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
