Question about Dishwashers
My dishwasher was in mid cycle when the door code appeared on the display. The door code now appears everytime i try to start the dishwasher. The door clicks in when i shut it so dont know what the problem is, please help.
    Sergeant:
    Novelist:
  • 196 Answers
Sounds like your door switch is faulty. Switch all power off. Then remove the control panel by unscrewing the screws holding it usually 6 or so and this will allow you to fold the control panel down gently. This will give you access to the door switch which is held on by 2 screws. Then swap it out with a new 1. You can order a new 1 from an online spares website by selecting you make and model. They are relatively inexpensive. Hope this helps.
Posted on Mar 15, 2011
Electrolux dishwasher won't run through a cycle?
So it would be desirable to write the ERROR appeared in
Dado
Aug 02, 2014 | Electrolux 24 " White Built-In Dishwasher...
Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
How to reset Blomberg DWT23100W computer?
Remove lower dish basket and inspect where water drains looking for clogged inlet
Jun 02, 2014 | Dishwashers
Cycle time remaining isnt displayed on Frigidaire Professional dishwasher
From my research, this unit is not designed to show it while in use only if stopped during a cycle or if a problem persists within the unit to cause a pause or error code to display.
Dec 22, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
What is the meaning and fix for error code E60 on a John Lewis JLDV08 tumble dryer. The dryer stops mid-cycle, the door pops open, and code E60 appears on the display.
When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
May 08, 2011 | Dryers
My new bosch axxis washer was20160uc does not start
Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
Oct 15, 2010 | Dishwashers
Does not appear to be cycling water or pumping
You have created a suds lock condition with the wrong soap.
Take a shop vac if possible and vacuum out all water and suds. No shop vac, bail and wipe with a towel.
Then fill with COLD water from the faucet. Start the was cycle a few seconds. Then DRAIN. Repeat with cold water, wash then drain several times until the suds are clear.
You will know the suds are clearing each time you refill with COLD water and start the cycle. It will begin to sound like it is washing and pumping rather than humming.
May 05, 2009 | Dishwashers
Zug Adora 12s Dishwasher
Perhaps the solution to your problem can be found in the User Guide-
Your model number appears with two suffixes; WW and BB thatmay only be color codes but user guides (which appear to be identical) areavailable for download from GE’s site:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-55031.PDF
Oct 02, 2008 | General Electric Adora GHDA670N Built-in...
Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 15, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
Top Dishwashers Experts
