Question about Dell Dimension 4700 PC Desktop
Loud noise from fan cpu not comin up - Dell Dimension 4700 PC Desktop
    Problem Solver:
  • 12 Answers
You probably should chek your fan
or you can look at your power supply it has a fan to
restart your computer go to setup mode "bios" and look at the temperature
Posted on Mar 15, 2011
2 Suggested Answers
  • 10406 Answers
SOURCE: dell optiplex GX280 PC
There probably is another fan, located inside the power-supply, that is making all the noise.
Borrow a stethoscope from a nurse or doctor, and listen to the noise, to pinpoint "where" on the computer that is the origin of the noise.
Posted on Jul 16, 2011
Acre z5700 turns off
A really loud fan can be one of two things - neither is very good to have for very long. Most newer motherboards support multi-speed fan operation based on CPU temperature. This keeps fan noise at a minimum because the fan only has to run fast (and loud) if the CPU exceeds a specific threshold temperature. The loud noise could also be from a fan that is starting to fail and is binding, thus running slower than normal. Either of these conditions is indicative of a problem that kills PCs - heat. Open the case and carefully examine the heat sink fins and the fan on the CPU. If they are caked with dust (especially the fins), then the CPU will likely overheat and shut down. Get some canned air designed for cleaning electronic components and blow the dust from the fins and the fan. Restart your system a see if the fan runs slower and quieter now, Machines that are in dusty environments, around smokers, or placed on the floor are especially prone to dirt buildup. Periodic cleaning with the canned air is the way to keep your PC happy and healthy.
Dec 10, 2013 | Acer Computers & Internet
Lightscribe
Hello Friend,
Some PC also noise like, SMPS fan, CPU fan, external cabinet connect fan. If this types of noise create then you clean all fan dust i think problem solved. You know CUP also create noise it`s default so not any solution.
Aug 22, 2013 | Compaq Hewlett Packard Presario SR5110NX ...
Fan noise
just check if any cable got stuck inside fan of cpu or anywhere.
open CPU and check keeping it open.
>>shut down pc
>>open CPU
>>check wether any cable stuck (if its not, uplug each cable and plug it prpoerly.. remove all dust)
>>try restart before fitting outside panal
may that help.........
Dec 17, 2012 | Computers & Internet
Dell optiplex GX280 PC when power on system no noise with fan after one hour making loud noise . I changed the CPU fan , also same noise, and applied heat sink paste to CPU and heat sink same noise....
Jul 16, 2011 | Dell OptiPlex GX280 PC Desktop
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
LOUD cooling fan noise comes and goes...usually when downloading and sometimes when just sitting unused. have cleaned it completely ...someone said possible fan drivers or heatsink (colling fins are...
Some fans are automatically temperature-controlled -- they speed up, and, of course, make more noise, as the temperature rises.
Background tasks, such as Windows Automatic Update and scheduled virus-scans, can cause the computer to become "busy" when otherwise "sitting unused".
Next time the noise increases, enter CTRL-ALT-DELETE and open "Task Manager", and click the "Performance" tab, to see if the CPU-usage is reaching 100%. Click the "Processes" tab, and then click on the 'CPU' column-heading, and click it a SECOND time, so that Windows lists the "top" consumers of CPU at the top of the list of processes. Which process is consuming the majority of the CPU?
Oct 26, 2009 | Computers & Internet
My sony vaio VGN-CS11S is soo noisy
The fan's bearings are probably going bad, or there may be some object that was sucked in to cause the noise.
Sep 28, 2009 | Sony CPU FAN CPU Fan
My cpu fan will not shut off it is so loud should i replace the fan or is there a way to repair this problem
Your CPU fan should always be on while the computer is on. If it's off, your computer is going to crach in a matter of time. The noise is normal. If it's to loud, replace the fan. Nothing major. But it is normal for the fan to be loud. Thats a good sign it's cooling the CPU. But you can get a shfter 1. Your computer might over heat though. Good luck.
Mar 05, 2009 | eMachines T5048 PC Desktop
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
CPU fan problem
The stock fans that comes with systems are usually fairly poor in construction and tend to fail. I would have a look at the fans and heat sinks on this website for a replacement.
I hope this helps,
Thanks for using FixYa,
Eric
Jan 20, 2009 | PNY VERTO GEFORCE 6600GT 128MB DDR3 PCIE...
Dell Dimension 4700 PC Desktop Logo
202 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
