I do not know how to remove the cartridge - Office Equipment & Supplies
  • BobLC Mar 15, 2011
    Please can you advise us the make and model of the printer
  • 93 Answers
You can search online for visual instruction mentioning your printer model no.
or, Follow this method:
  • Turn your printer on
  • Open the front side of your printer, there should be a instruction like "Open here"
  • Wait until your cartridge stop moving.
  • Look for the instruction level mentioning how to remove the cartridge.
  • Follow the instruction and remove them.
Posted on Mar 15, 2011
Photo ink
Remove the tab from your photo cartridge. Power the printer. Open the printer cover and the cartridges should move to be accessible. Remove the color cartridge: move it gently toward you and remove. Insert the photo cartridge. Close the printer cover.
Jun 13, 2009 | HP Photosmart C3180 All-In-One InkJet...
How to change the ink in a Canon PIXMA MX310?
  1. Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
May 27, 2009 | Canon PIXMA MX310 All-In-One Printer
I wanna remove Black ink cartridge from the printer.
lemme know the printer model number. All you need to do is open the cartridge access door open the latch covering the cartridge push the cartridge from the top ,a little downwards and pull the cartridge
Lemme know if that helps
Hp Technician for All-in-one printers
Apr 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Don't know how to install ink
Installing print cartridges
1 Open the printer, and then press down on the cartridge carrier levers.
2 Remove the used print cartridge or cartridges.
3 If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid.
Warning—Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridge.
4 If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid.
5 Close the printer, making sure to keep your hands out from underneath the scanner unit.
Removing a used print cartridge
1 Make sure the printer is on.
2 Lift the scanner unit.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid.
4 Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Apr 13, 2009 | Lexmark X4650 InkJet Printer
Replace cartridge
The tool you see in the instructions is probably a faucet stem wrench. An adjustable (thumb) wrench could be used to remove the retainer.
Mar 26, 2009 | Grohe Chiara Neu Lavatory Centerset ...
Dont know how to remove the Cartridge
Do you have a users manual of your printer? You can read the procedure in there to remove the cartridge. if you post the model of your printer then i can't tell you the correct procedure.
melnavz
Feb 27, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
X1270 NO COLOR PRINTING
I know what you mean by an inexpensive printer. The cartridges cost more than the printers! A simple, but often overlooked solution is to make sure that the tape protecting the bottom of the cartridge has been removed. Check that and let me know the results.
Aug 19, 2008 | Lexmark X1270 All-In-One InkJet Printer
Ink cartridge
you have to on the printer. Then you open up the front cover, the cartridge place will move to the center of the printer.  push the lock button of the cartridge and you may remove the old cartridge. You have to remove the old cartridge and change with the new one.
May 06, 2008 | Lexmark Z600 InkJet Printer
Remove used cartridge
hi , its simple, turn on the printer open the cover/lid , the cartridge carrage will come in the center, unlock the cartg and carefully pull it out..let me know..
Dec 10, 2007 | HP DeskJet 5150 InkJet Printer
46 people viewed this question
jasbo
jasbo
