Question about Slendertone Fortex
Hi, my slendertone flex pro keep beeping with the triangle signal. how to avoid the sound? annoying
2 Suggested Answers
  • 1116 Answers
SOURCE: I just replaced the pads
Triangle error code denotes a pad contact problem.
These are the solutions for this error:
The triangle symbol has appeared on the LCD*
Pads not covering metal stud
Pads are worn
Pads on wrong way around
Liners still on the pads
Reposition pads
Contact your local distributor for new Slendertone pads
Ensure black surface of pad is facing you
Ensure liners are removed from both sides of the pads
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 02, 2011
I want to watch the get started video on The Flex Belt, How to get started.
Flex Belt - YouTube
? 8:16
https://www.youtube.com/watch?v=gBYvxDeb5VY
Jun 28, 2013 - Uploaded by flexbeltabbelt
We've created helpful videos that will walk you through the easy set-up process. It is very simple to set up The Flex Belt and only takes a couple of minutes... ... tips for awesome results and help you with any questions you may have. ... Getting Started with your Flex Belt - Duration: 8:08. by flexbeltabbelt ...
The Flex Belt video review - YouTube
Dec 08, 2015 | Slendertone Flex Pro Abdominal Muscle...
Slendertone keeps beeping
the beeping its becouse there is no contact between the pads and the skin (1), or the cables and the pads (2), or the cables and the controller (3).
what the manufacturer says:
try to change the pads by new ones
i did that, but still not working.
what i do:
i had the second problem, but i fix it, i cut the cloth in the back part of the pin (not in the front of the pin), and i discover that the cable that is attached to the pin was cut, i remove the the pin, then i replaced with a bolt, i attch the cable to the bolt and thats all.
i'm using it right now and its works great.
i answer on another post similar to this one, a put a link to my google account where you can see pictures of what i did.
thums up! thank you!
Dec 28, 2013 | Slendertone Fortex
Error e002 slendertone flex belt
Dear Karen! I have the same problem white my slendertone e002 error,if you deal whit it,please helm me!
Oct 24, 2012 | Slendertone Abdominal Muscle Toner
Hi There,i need to know,my russel hopps steamer is making a beep sound the whole time. what am i doing wrong? the sound is very annoying
Hi, ok I also had that problem whereby the steamer keeps on beeping. It's a warning alarm. we need to fill the steamer with water directly into the reservoir and NOT into the side. the side is only for top up during the steaming process.
Hope this helps.
Sep 27, 2011 | Russell Hobbs RHST3 Rice Cooker
My slendertone belt keeps beeping with a triangle next to it. I can't turn up the intensity and it won't vibrate but I'm not sure why. What's the problem?
I just replaced new pads but that triangle still appear. Can't really do anything with the belt right now. Really frustrating.
Feb 18, 2011 | Slendertone Fortex
My facebook chat keeps being unavailable on my laptop but works ok on the computer in the other room it just keeps showing a yellow triangle
this happens when the networking device of your laptop is turned weak or about to go off.because of the weak signal receiving it keeps on breaking the connection and makes it unavailable. to solve the issue you need to get the signaling device of your laptop checked and if necessary get it replaced to avoid further inconvenience
thanks.
Aug 31, 2009 | Facebook Social Network
Beeping
Hi
call your camcorder manufacturer and inquire for a firmware that supports the memory stick. chances are its not compatible with the camcorder since this handles large memory.\
Hope this help
Jan 11, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Pro-95 dual-trunk scanner
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Aug 01, 2007 | Radio Shack Pro-95 Handheld Scanner
Pro-95 dual trunk-tracking handheld scanner from Radio Shack
Firstly make sure the "squelch" is set as per the manual (link below) page 26. http://support.radioshack.com/support_electronics/doc69/69487.pdf If that fails I suggest initializing the scanner to factory defaults as below:
Slendertone Fortex Logo
908 people viewed this question
Top Slendertone Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Slendertone Exercise and Fitnes Expert? Answer questions, earn points and help others
