When I put paper in the document feeder, the paper doesn't come out and gets stuck.
  • 428 Answers
Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. Sometime one side grips well and tries to pick the paper while the other doesn't resulting in a jammed. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Posted on Mar 15, 2011
Testimonial: "Thanks!"
What does ADF document mean?
"Document in ADF", usually means that there is a document in the Automatic Document Feeder. Or to put it differently, there is a paper jam in the document feeder (probably of the scanner part).
The fix is to check the feeder and clear the jam. Sometimes it indicates there is a piece of paper stuck or a faulty paper detector.
Dec 26, 2014 | Office Equipment & Supplies
Document feeder error message
did u guys ever use maginzes to scan documents with they will get jamed in there i would open it up cheak feeders closly ok thx nick
Feb 09, 2008 | Office Equipment & Supplies
The paper you scan is stuck
There is debris blocking the paper path in the document feeder. This could be a staple or a shard of torn paper blocking the path wedged into a tooth of the diverter arm or a sensor flag. I would suggest that if there is a small wheel or knob closest to you when you raise the document feed lid, put a piece of #28 lbs card-stock into the document feeder guides, turn the wheel/knob to pull the paper/cardstock into the ADF and continue until it either pushes the shard/debris out or stops moving the paper no matter how much you turn the wheel/knob. This will tell you where in the ADF (Automatic Document Feeder) the blockage is located.
Nov 06, 2013 | HP OfficeJet Pro K8600 Printer
1350 toshiba copier copy gets stuck
You need to clean the feed rollers for all your trays and for your document feeder or adf. If that doesn't work then replace them. But before you do that try checking if there is any paper, ripped or otherwise blocking paper path and removie it. It may just be that simple.
TOSHIBA BD 1350 SUPPLIES
Sep 12, 2012 | Toshiba T1350 T-1350 Compatible Copier...
My printer says "close document feeder cover". I don't know where this is
It is talking about the flap that is on the very top just above where one puts in an original to auto feed on to the glass, this access cover is required to be open and closed by the machine because it feels something is holding it open or its switch that tells it such is stuck. Maybe a jam from last original fed into it..
The cover once open check around for paper fragment and inspect little levers that hang down, one is stuck or there is paper stuck in Document feeder
I have found that often label bits, paper clips, punch bits and small corners of paper often get in the path, I use a piece of laminate cut so it has a v or a point and feed it in the document feeder, manually inserting it in the direction a piece of paper normal travels in it.
Push it all the way threw not pulling back (bad for it) to do so poke the point threw, you will need the top cover open and lift off the glass, so you can grap the point and pull the laminate threw.
Nov 04, 2009 | HP OfficeJet d145 InkJet Printer
Canon 1023if auto feeder not working. Says check
The document feeder has multiple sensors in it. sometimes they hang up and stay stuck out of place. Other sensors might get paper dust on the face of the sensor. If you can open the document cover, locate the sensors and see if any are ajar or the sensor flag fell out of place. Also look to see if a paper is stuck in any of the paper path areas. Not seeing the machine it is hard to say if it fed paper and says check document, if it did, clean the feed wheels with a wet paper towel.
Oct 15, 2009 | Canon imageRUNNER 1023iF Black and White...
When paper is going into the paper feeder it is is getting wrinkled immediately and jamming the feeder
Sounds like someone got something stuck in the ADF (Auto Document feeder). See if it looks like the paper is really getting wrinkled up more on one end than the other and focus on that side of the feeder. I have seen post it notes cause this problem. People put in their originals and forget to remove post it notes before feeding the documents through. They come off and get stuck in the feeder. Without more detail it is hard to say what is stuck in there but it sounds like there is something impeeding the paper path. Shine a flashlight in there to see.
Oct 03, 2009 | Minolta Di3010 Copier
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
123 people viewed this question
k24674
jasbo
jasbo
