Question about Hotpoint WMA58 Front Load Washer
Mr WMA58 has been stuck on a program and is not draining properly. I can't open the door as there's water in the machine, what can I do?
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 15, 2011
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 | Dishwashers
Hotpoint Aquarius WMA58 washes, spins but won't drain water away !
I would check the filter assembly and the drain line to see if there is an obstruction visible or twist in the line that you could smooth out. The drain solenoid valve could be faulty and just isn't opening any longer. It's an electrically operated valve that makes a rather loud "click" when it energizes to open the drain and let the water flow out.
Dec 28, 2016 | Hotpoint Washing Machines
Water will not drain
just wait until summer because it's the time of the year that evaporation is faster, because of that, the water inside your washing machine will evaporate asap!
Mar 06, 2012 | Hotpoint WMA58 Front Load Washer
How make the door open automatically when finish the laundry
Welcome to FixYa,
These model of Asko ( based on the number listed ) do not have such an option. On these models the Program Control knob must be at the end of a program (at the 12:00 or zero position) to open the glass door.
If you need to stop or interrupt a program after you start the machine, turn the Program Control knob
to 10 (Drain). Any water in the machine will be pumped out and you can then press the Door Open
button ( ) to open the door. To restart the washer, close the door and turn the controls to the desired
settings.
On the electronic control models, if you need to open the glass door during a wash or rinse cycle, press and hold the Door Open button for three seconds. The machine will stop and automatically drain enough water so the door can be opened safely. The program will resume when you close the door. The inlet valve will come on to
ensure the proper water level.
In case of mechanical failure, you can use the Emergency Door Opener located by the drain pump. To use the Emergency Door Opener, remove the screw holding the cord handle (loop) and pull the cord down.
Hope this answers your question even if it isn't necessarily the answer you wanted. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Jan 10, 2011 | Asko W6021 Front Load Washer
I have an Electrolux EW 548 F Washing machine. It stopped while in a cycle and it won't continue or let me open the door to get the clothes out.
It sounds as if something has got stuck in the filter jamming the drain pump,try draining the water out either through the filter but beware of the amount of water.Or take the drain pipe at rear and try to drain iinto a container or through the nearest door to an outside drain.Once the water is out you should be able to open the door.Then you will have to find out if some object is stuck in the filter(located at bottom right hand side).
May 03, 2010 | Electrolux Washing Machines
Hi i am having trouble with our wma58, the last 2 washes it has sounded noisy on start up but then washed fine yesterday i put the machine on it seemed to get half way through a cycle then stop all the...
Try the following.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to the bottom of the drum.
Remove and clean the filter inside the hose.
Remove the black hose onto the pump, and check for blockage or obstruction here and in the pump.
Hopefully, this will solve your problem.
Good luck.
Dec 13, 2009 | Hotpoint WMA58 Front Load Washer
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
Door wont open
The door switch could have stuck closed. there is a way to open it up manually.
if you can just access the water pump filter cover, and at the back part of the door switch you will find a plastic ring attached to the door switch, pull it down to open the door.
drain first the water if there is water left in the unit by slowly opening the water drain filter cover and drain the water slowly.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Washing Machines
Under filling
Check your drain hose. It should be at the same height as the top of your machine. If not high enough, make a loop that is high enough. The water could be syphoning out of machine as it fills.
Oct 09, 2007 | Hotpoint WMA58 Front Load Washer
Inside of Washer Smells
often in washing machines there is a drain trap which needs cleaning out from time to time, (usually accessible from the front behind a removable facia) The manual should tell you how to clean this. you need to drain the water first (as there is often a little water still in the system). if you look on the program dial there is often an item that has an arrow pointing down, this should be the drain program, after this is done you can remove the draining cover and clean the workings inside, hopefullt this will solve your problem :)
Sep 27, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Hotpoint WMA58 Front Load Washer Logo
82 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
