Question about Panasonic SCBT230 Theater System
I have a panasonic sc-bt230 wich is showing the F61 problem. i have just replaced the fan for a brand new one and the problem did not go way. Any idea anyone
5 Suggested Answers
SOURCE: SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Posted on Apr 14, 2009
lock123
  • 6831 Answers
SOURCE: Repeated F61 fault code on Panasonic Home cinema
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Posted on Dec 12, 2009
Testimonial: "Sounds most probable, so have just finished dusting it and will let you know outcome, many thanks. H"
SOURCE: how can i get the system to work with my tv
if you have it connected with the HDMI cable to your tv, use the ARC on the receiver to hear audio out.
Posted on Jul 18, 2010
SOURCE: is panasonic sa-bt230 vs sc-bt230
sc-bt230 is the name of the whole system, sa-bt230 is the name of the main unit only
Posted on Oct 24, 2010
Replaced the side fan with the factory part. Now get an f61 error. reconnecting the old fan correects the f61 error. What can be done?
return the new fan as defective and start again with another and mention your issue, either new fan bad or wrong one.
Dec 03, 2012 | Panasonic SC-HT441 Theater System
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
Hello i get the F61 err on my Panasonic SA-DT100. i have cleaned the fan and it works but still i got the error
Maybe the fan doesn't rotate at the proper speed. Try to put some oil on the bearing sleeve or even replace the fan.
If it offers resistance it will show F61 and disconnect.
Nov 16, 2010 | Panasonic SC-DT100 System
Is panasonic sa-bt230 vs sc-bt230 the same?
Sep 29, 2010 | Panasonic SCBT230 Theater System
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
NOISEY FAN
You may need a new fan, but you can try cleaning the fan. Remove fan from player. use a few drops of WD-40 or another similar lubricant, the fans label may need to be removed. Note Panasonic fans must be rotating or f61 code will appear. Hope this helps.
Jan 10, 2009 | Panasonic Home Theater System System
Panasonic SA-AK600
Try to power on the unit without the speakers connected. If it works normally without the error showing, then a speaker wire maybe shorted or a speaker defective. If the error F61 is still there, then most likely the Regulator IC is defective in the unit.
May 30, 2008 | Panasonic SC-AK600 CD Shelf System
F61
check the fan
If one fan dosent work it will show the error F61
May 15, 2008 | Panasonic SC-HT940 System
F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
Dec 05, 2007 | Panasonic SC-AK78 CD Shelf System
Panasonic SCBT230 Theater System Logo
1,701 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
