Question about LaCie Computers & Internet
WINDOWS 7 DOES NOT OPEN HARD DRIVE - LaCie Computers & Internet
    Scholar:
  • 158 Answers
You cant open the harddrive only the cd/dvd. The harddrive is a physical component inside of your computer that store your files. If you are having a different problem please try to word it different and I can help
Posted on Mar 15, 2011
Upgraded from windows 7 to windows 8 ,now storage device not showing.
Have you tried to shut down the computer, unplug the usd external drive, reboot the computer, plug in the USB external HDD the should apply the driver. That said, Have you tried a Thumb Drive or any other USB device in the USB ports? It's a common problem when upgrading a OS that Hardware issues popup. Open the Device Manager, Is your USB controller working? Enabled? Any other devices in error? Unknown devices? Use the Win 7 drivers for your computer found on the computer manufacturer's website. Change the compatibility on the driver for Win 8.
Jan 11, 2013 | Western Digital 1TB WD ELEMENTS USB...
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
"How do I transfer individual files archived on my SimpleDrive from old PC to newer HP Windows 7 laptop?"
Connect your simple drive to the computer with the usb and power lead if applicable.
Click start all programs accessories open windows explorer my computer you should see your drives C: usually your hard drive D: your cd dvd drive and your usb drive E: or F: click to open it from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to your usb drive disc then drop them Hope this helps.
Jan 10, 2013 | SimpleTech SimpleDrive Pininfarina 320GB...
How do you set up an external hard drive?
Turn your computer on and plug the external hard drive into the computer.
Open "Computer Management" by clicking "Start," "Control Panel," "System and Security," "Administrative Tools" and "Computer Management."
Click "Disk Management" in the left pane under "Storage."
Locate your external drive from the list of hard drives connected or installed on your computer.
Right-click the drive and select "Format."
Select a file format from the drop-down menu. Choose "NTFS" if you will be using the external hard drive with a computer that uses Windows 7, Windows Vista or Windows XP.
If you will be using the hard drive with an older version of Windows, select "FAT32."
This is a much less common format.
Click "OK" twice and your external drive is formatted. Once the drive is formatted, it is properly set up to be used with your computer.
hope this helps
Sep 10, 2012 | Computers & Internet
I have external hard disk 500g seagate. it dosen't open and disapper not accessible (error performing inpage operation)" message. what do i? it's very important for me.
Hi ahmad1353,
You might be experiencing some problem with the hard drive itself so here's what you can try;
Open command prompt(if your using Windows): Click start -> Run(if your using Windows 7 just type CMD on the start search) type CMD and press Enter.
On the Command Prompt(black screen with a blinking cursor) type the following command;
chkdsk [drive:] /F - wherein [drive] is the drive letter for you Seagate external hard drive(to check just double clieck MyComputer(Computer for Windows 7) and look for the drive letter. This should scan the external hard drive for any problems and hopefully provide a fix for you to be able to access your files.
For more reference you can go can access the site below.
http://support.microsoft.com/kb/315265
http://answers.microsoft.com/en-us/windows/forum/windows_7-performance/using-windows-7-how-do-i-run-chkdsk/a68b3e4d-1a42-e011-9767-d8d385dcbb12
Aug 15, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I've got a 2 TB WD Elements external hard drive, and suddenly, no computer wants to recognize it when I plug it in. It is just rejected by any pc i've tried (3 laptops so far...) and I've a...
Is the PC you've used before is the operating system is windows Xp? If you've using windows Xp before then you've plug it in a windows 7 Operating system, it means your hard disc have no problem the operating system of your PC is different than before. Try to plug it in a windows Xp operating system then recover it in there then format it in a windows 7 operating system then, the windows Xp and windows 7 try to make a network place in the connection then share the hard disc files that you've recovered then copy and paste it in the newly format hard drive that formated in a windows 7 operating system.
Jul 21, 2011 | Western Digital Elements 2 TB USB 2.0...
Copy WIndows XP from one hard drive to another
Why are wanting to clone your hard drive to another on when all you need to do is install Windows 7 directly onto the new hard drive?
Are you wanting to save all your settings and data before you install Win 7 over the top of XP?
Jul 20, 2010 | Microsoft Windows XP Professional for PC
Old maxtor 3200, new computer windows 7. how can i make it work/
Maxtor manufacturer says that this drive is not ready for windows 7 and no driver had been issued. you will have to connect it to another computer to recover the data, or to use another computer in your network to access it and share the resource with your pc with windows 7
Apr 28, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Gateway hard drive is continously running
no windows 7 is still in its birth mode so theres alot of things that windows 7 will not like. Your best bet is not to add things to win7 that the operating system will not like also you should of contacted microsoft support on this issue so the can help you to resolve this problem and make a patch for others having the same issues
Jan 26, 2010 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
