Question about Spidem Divina De Luxe Espresso & Coffee Maker
How to change language on my coffee machiner - Spidem Divina De Luxe Espresso & Coffee Maker
  • 114 Answers
Try to enter in the programming mode, check your manual and see if you can find a Language item or something:
• Ensure that the ON/OFF switch of the appliance is switched to "O" and that the hot water knob is OFF.
• Press the buttons (23) and (25) and (see the back of the machine or the manual), at the same time, switch ON the appliance using the ON/OFF switch .
Posted on Mar 15, 2011
How to change language? It suddenly changed by itself after 3 years use.
In the standard menu (display), select the "More" button until you see "Settings" in the menu. Select that item and you will see the "language" option. Select "language" and then select the desired language.
Jul 19, 2014 | Miele CVA4070 Coffee Maker
Change language from german french
The machines usually come with the language in the country they are bought in. You want to change the language. Once you are in the programming mode, press the up and/or down button until you come to language then press OK or equivalent. Then press up/ down until you come to the desired language and press OK. I hope this works for you, all the best Kolbrun
Sep 19, 2013 | Saeco Coffee Makers & Espresso Machines
Hi i was given a coffee machine by my frein the only thing is its in german can i change the language
Hi You need to change your language in the menu. Push and hold the menu button. When it changes in the window, use the up or down arrow button to move the asterisk (*) until you come to a window that has something like "lingua, or spreka", and then push the menu button again. Use the up arrow to scroll to "English". When you have the asterisk (*) in front of English, push the menu button again. You have selected English and then you can push the escape button to exit. Some machines have exit in the scroll bar, so it depends on your machine.
Jun 18, 2011 | Saeco Stratos Coffee Maker, Espresso...
How do I change the display language to English from German?
Here is a link to the instruction manual http://dl.owneriq.net/f/f4753fec-f772-34c4-59b4-8c5d346f7941.pdf
While this other link is not your specific model, it is close and does offer instructions for changing the language that might be able to help you - http://www.kuppersbuschusa.com/Documents/Use_Care_Guide/EKV6600-0_UandC_Guide.pdf
Jun 15, 2010 | Kuppersbusch K?ppersbusch EKV 6800.0 M...
Changing language display from nederlands to english
Push down the rotaryswitch until it lights up. Turn counterclockwise until you find the language menu, you should look for Sprache, spraak or something like that. Push the rotary again, and tur to English. Push to confirm, and then Exit
Sep 24, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
I have a saeco vienna digital, it gives a message: Perc.un.ontbr. What does it mean?
Hi
Go into your menu (bottom left) and scroll (up or down arrows) to language. Push the "OK" button and change it to English and push the "OK" button. Your is on the wrong language.
Jun 21, 2009 | Starbucks Saeco Italia Digital Barista...
Instruction manual for Solis Master5000 / digital
Turn on the machine. Hold down the button that says steam/enter (the one below the blue button) until it says "Sprache" and "Wasserh.." . The cursor will be blinking beside Sprache. Use the down/up arrows (the large coffee and espresso cup buttons) to scroll until you find English. Hit 'enter' (steam/enter button) to set the language to English. Hit 'escape' (the tall coffee button) and your language should be set to English. You can also go to solis.ch and download a manual for your machine. Good Luck!
Dec 15, 2008 | Solis Master 5000 Espresso Machine
Chaged language by accident
My language got changed by accident one day as well.
If you look into your owners manual, or download one if it is lost.
Cycle through the functions
When the function appears,
select it using the
“menu” button.
Select the desired language.
Press the “menu” button to
confirm your choice.
Oct 25, 2008 | Saeco Magic Comfort Plus Espresso Machine
How can i change language to english
Press menu
press Med cup(arrow down) twice
Press menu
Then use small cup(arrow up) or med cup (arrow down) to scroll through the different languages.
Once you have found english press menu.
Press large cup (escape key)to exit menu.
Done!!
Sep 20, 2008 | Gaggia Titanium Espresso Machine
Machine display changed to German
HI,
Yeah, when the machine is turned on, you click the "p" button (the descale button, actually, the one in the top right corner). This will put it into programming or selection mode. First, it will ask you about tome (or "heurs" in french, if it has defaulted back to the original language). You can cycle through a series of ssettings by pressing the button multiple times. One of the settings is the language setting, and you press the btton below the "p" button (i think it is the Large Coffee button) to choose from the different languages. When it is on english, you press the "p" button again to move on.
It sounds complicated, it really isn't.
Cheers,
Frederik
Jul 11, 2008 | Nespresso D300 Espresso Machine
Spidem Divina De Luxe Espresso & Coffee Maker Logo
425 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
graybeard32301
ray gallant
nikolay nikolov
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
