Question about HP ProBook 4510s Notebook
I have an hp probook 4510s and my mouse just freezes from time to time. or it just starts to scroll staff on its on. It never used to do this. If i uninstall the synaptics driver it works fine but it may happen again after a long while too. everything else will be working except the mouse. please help
  • 7 Answers
SOURCE: inoperative touchpad scroll zone
rwertheim,
I have a MX8711.
I assume you are running Vista.
After you have updated your virus protector program and run a complete scan. You "could" be fixing it and if it is a virus problem, it is immediately reinfecting the driver. If it still doesn't work, I recommend you:
1. Rollback the driver of your touchpad. If it was working, this might do the trick. You can do this at Control Panel > Mouse > Hardware (tab) > Properties (button) > Driver (tab). If it has been updated and that caused the problem, you probably can "Roll Back" to the previous driver and that option will be highlighted.
2. If not, then your driver is probably corrupted. Go to Gateway Support and download the touchpad application file for your computer and SAVE IT TO YOU DESKTOP AND DO NOT RUN IT. Replacing only the driver usually doesn't work in these cases but try that first. Go to Control Panel > System > Device Manager > click on the (+) sign by mice and dbl click on the Symantics PS/2 Port Touchpad (or what ever yours is) > Driver (tab) > Uninstall. When you restart, it should reload the driver from the application that is still installed.
3. If that dosn't work, I recommend uninstall the application from Control Panel > Programs & Features. Restart your computer and install the application you saved on your desktop.
I hope this helps.
Have a blessed day.
Tracker Tom
Posted on Jun 06, 2008
SOURCE: HP Pavilion dv9000 scroll on mouse pad has stopped working
I have the same laptop and I have noticed that it does not work in certain applications or on certain webpages. I have also found that the scroll only works when the mouse pointer is over the part of the page that would scrool (over the text your typing in word, or over the actual webpage in IE7).
However, since you have having problems with Windows crashing when trying to check the settings, and with getting no response from the task bar, you may want to consider defragmenting your hard drive, running some type of Spyware remover (Ad aware by lavasoft is a good one) or SpyBot search and destroy. They are both free as well, and a simple search on download.com should find them. If the problems persist, it may be time to reinstall Windows. Just make sure you back up anything you will want off the computer to CD or DVD first because you will loose everything.
Posted on Jul 24, 2008
  • 54 Answers
SOURCE: touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
Posted on Mar 14, 2009
  • 2973 Answers
SOURCE: hp probook 4510s cannot get cd tray open
Maryar,
The tray may have got stuck. It happens. What you can do is look for a small hole on the face of the drive, either on the tray front or just below it. Insert a paper pin through it. The pin will press a lever which will open the tray. If you do it a few times the tray may get unstuck finally. Hopefully.
Posted on Dec 13, 2009
SOURCE: why windows xp won't shut down in hp probook 4510s
Just delete webcamera software or use default driver for it
И будет тебе счастье
Posted on Mar 25, 2010
Music recording on HP ProBook 4510s would it work ?
does it need fixing? this is fixya not your personal assistant,,
Jul 29, 2015 | HP ProBook 4510s Notebook
Probook 4510s bluetooth wont work
Try reinstalling or updating the device drivers. Click on the Link below:
HP ProBook 4510s Notebook PC
Jul 06, 2014 | HP ProBook 4510s Notebook
Hi, i hav a probook 4510s laptop & i cant get the mouse pad to work... when the lappy is starting up, in the left hand top corner is says - no mouse detected. please help!
If this is a recent occurance, shut down, unplug, remove battery, plug in, push the on/off button and do a System Restore to a date before this problem. Perhaps the TouchPad driver is in error. You can try a external USB mouse to troubleshoot the problem in Device Manager to verify the driver or device isn't in error. I think HP TouchPad software is Synaptics Pointing Device, check your your Tray Notification Area for the icon, right click, select Pointing Device Properties. Or Control Panel, select Mouse.
Nov 29, 2013 | HP ProBook 4510s FM849UT Notebook
How to fix my hp mini5101 touch pad, it's not working
try using an external usb mouse then try an repair your touch mouse
Sep 12, 2011 | HP ProBook 4510s FM849UT Notebook
In my Probook 4510s, the Left Click Moouse button functions as the Right Click one.
first open control panel there u will get the option of mouse please tick out this option " switch primary and secondary button ".
Sep 09, 2011 | HP ProBook 4510s FM849UT Notebook
How do I remover the power button cover for my probook 4510s ?
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01905586/c01905586.pdf
That is the link to the service manual for the Probook 4510s. I believe what you're looking for starts on page 64. HP and Dell are both pretty good about putting the service manuals online for anyone to use for reference. For more manuals about the Probook 4510s check out
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=3934828
May 10, 2011 | HP ProBook 4510s FM849UT Notebook
My HP Probook 4510s has fan running continually and just switches off a couple of times a day now. Just gets worse
if fujitsu start snd u hear noise in machine but it does no display on a screen and screen is black what is the cause i want to know..............
Dec 21, 2010 | HP ProBook 4510s FM849UT Notebook
I am using an HP ProBook 4510s. My touch pad keeps freezing on me. Sometimes it will work for a few minutes and then freeze and sometimes the computer boots up with the message No Mouse detected. Any...
I have a 4510s and had this problem before.
Part of the problem was synaptics driver was freezing, Driver Synaptics software upgrade may help if that is part of your problem.
Have you opened the notebook to upgrade or remove the HDD for any reason?
If so, you should make sure the plastic of the palmrest (which houses the touchpad mouse) has been correctly fitted back in place. It may also help to remove the palmrest and ensure the flexible cable is correctly inserted in the ZIF connector.
I also notice there are some contact points from the PC to the underside of the trackpad, it may pay to clean those with metho to make sure the electrical connection is good.
Sep 09, 2010 | Computers & Internet
HP ProBook 4510s Notebook Logo
347 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
