Question about Radio Communications
GENTEX P/N 93C8580 WIRING DIAGRAM TO GA PLUGS
How do I find a wire diagram for a 4949cc mini choppers ga-643f
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
http://www.tootoo.com/idetail/49cc-mini-chopper-with-two-strokes-ga-643f_24495635_721073_6878978_16262765
49cc mini chopper wiring diagram Google Search
Download 49cc mini chopper wiring diagram
APC Mini Chopper Key Switch
Dec 15, 2015 | Motorcycles
Ampmeter wiring 65 c10 pickup
the amp meter has 2 terminals 1 goes to batt other goes to everything else except starter that hooks up to the batt if it reads backwards switch the 2 wires at the amp meter
Jan 18, 2014 | Car Audio & Video
Wiring diagram for ga-7vtxe motherboard
Hello you can download the manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=1310#manual
You will need adobe reader to read the content.
The drivers can be downloaded here:
http://www.gigabyte.com/products/product-page.aspx?pid=1310#driver
But first select your windows system.
Good luck
Jan 10, 2013 | Gigabyte GA-7VTXE Motherboard
Wiring diagram
Cut and paste this URL. Select and download the motherboard manual. All the wiring connection information is in the book.
http://www.gigabyte.com/products/product-page.aspx?pid=1579#manual
Jan 07, 2012 | Gigabyte GA-5SMM Motherboard
Need a wiring diagram for gigabyte motherboard model: GA-81E please.
Hello.
The motherboard you are searching for is actually the GA-8IE, and by following this link you can download the manual directly from Gigabyte.
Jun 29, 2011 | Computers & Internet
I need a gigabyte motherboard wiring diagram for model GA-P35-S3G
http://www.gigabyte.com.tw/Support/Motherboard/Manual_DownloadFile.aspx?FileType=Manual&FileID=18320
You can download the manual for your GA-P35-S3G from this site.
Jan 13, 2010 | Intel Motherboard
Cables not connected for power, hdd light another
http://www.tomshardware.com/forum/261599-30-8istx-wiring-power-switch
Jul 23, 2009 | Intel D845GVSR Motherboard
I need a wiring diagram for a 2001 ford f150 trailer hitch plug in. i got a new heavy duty trailer connector and i need to know the color code of the wires
Hey Bryan
I've got them for Six and Four wire plugs
Six wire plugs:
Horse, stock or utility trailers:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
May 02, 2009 | 2001 Ford F150 Styleside SuperCrew
How to connect plugs of front panel in the main board?
the power switch connector goes vertically where it says pw on the pins at the bottom right of the board. there is a diagram in the user manual on page 23. you can download the manual fro their website.
Thanks
Apr 05, 2009 | Gigabyte GA-7IXE4 (GA-71XE4) Motherboard
AUTO DIMMING MIRROR
The Donnelly mirrors use the same 7-pin plug as the Gentex, but the pin-outs are different. Here is the pin-out for the Donnelly mirrors:
Pin 1 - +12 volts
Pin 2 - Courtesy lamp input
Pin 3 - (varies depending on mirror features)
Pin 4 - (varies depending on mirror features)
Pin 5 - Reverse disable (+12 volts in reverse)
Pin 6 - Ground
Pin 7 - Demand lighting input
Aug 22, 2008 | 1998 Buick Century
Radio Communications Logo
184 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
