I purchased a yamaha sound bar YHT-S400 and while installing it I realised that the HDMI output port was damaged ( by me i guess,don't know how ??? ) Is it easy to just buy a HDMI port and replace it or is it like opening a can of worm, Thank you, Reza.
  • 26 Answers
HDMI jacks are a difficult item to replace. There are numerous connection points that are attached to a circuit board within the unit. If the jack no longer works, unfortunately it would need a professional to repair or hopefully a store return/warranty claim.
In other words, its a can of worms.
Posted on Mar 16, 2011
Testimonial: "Thank you for a quick reply, it probably saved me a lot of time and hassle not doing it myself"
I hooked up my soundbar using the HDMI out (TV) port from bar to HDMI in port on my Philips TV power is on bar however I can't get any sound out of bar. But just audio cables worked what to do?
OK, If its the Samsung Sound Bar, this item should have 2 HDMI input, 1 3.5mm audio jack input and a digital audio input (fiber optic). Since there are various input, the remote control should have a source button, or it will probably read O/A Input, this is to change thru the inputs from the sound bar. If you connected your TV HDMI output to HDMI 1 from the Sound Bar, then press the source button to reach HDMI 1, maybe it will be display with a different name, like sound 1, or DIGI.1 Give it a shot and let me know in the comment section. Good luck.
Dec 19, 2015 | Samsung HW-H450 2.1 Channel 290 Watt...
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Laptop to T.V. connectivity
Hello!
This is my first time using this site, but I will try my best to assist you.
From what I understand, you want to connect your laptop display to your T.V. In turn using your T.V. as a "monitor".
So you were wondering if you could use a S400 to HDMI cable to accomplish this. Unfortunately I don't believe this is possible with that cable. To my best knowledge, S400 ports are only capable of transferring DATA between devices, not VIDEO. A VGA or HDMI cable will accomplish what you want. I don't think your laptop has a HDMI port, so I recommend buying a male-to-male VGA cable.
I looked up your T.V. and it looks it should have a VGA input port. This is what I did for my laptop and 32 inch LCD T.V. when i accidently cracked my laptop's screen.
It may not be High Definition, but you should be able to get fairly decent resolution. Make sure your T.V. is on the "Computer" input channel. (Or equivalent)
I don't recommend buying a VGA to HDMI cable converter as it usually doesn't result in improved quality.
I hope this helps! Good luck!
Jan 21, 2013 | Computers & Internet
I just recently purchased a playstation 3 and have the hdmi connected to my lcd monitor and a optical cable connected from the playstation 3 to my yamaha htr-6230 but no sound. I disconnected the optical...
Well,From what it sounds like,You could try a different cord.Or the settings are wrong on the t.v. Have You tried going to settings>Sound settings and turning the vol. up.
Apr 25, 2011 | Yamaha YHT-391BL Theater System
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Feb 25, 2010 | Yamaha YHT-390 Theater System
What is the correct wiring connection using hdmi and optical cables from a lcd tv to yamaha yht292
If you tv has a hdmi input, connect it to the Yahama receiver hdmi output (out). If you are using a satellite receiver, digital converter, or a cable box with hdmi output(s), connect them to the Yahama hdmi input (in) for video and audio signals. If the above box(es) do not have hdmi capabilities, then connect the box(es) to the Yahama with either component (preferred), svideo, or yellow RCA compsite video jack (least preferred) for the video signal. For audio, connect the box(es) with optical or coax (preferred) or left-right-center-front-rear patch cords.
It really all depends on what outputs are available on the boxes and/or signal source(s).
Hope this helps,
Rhais
Sep 19, 2009 | Yamaha YHT-390 Theater System
I'm not getting YHT 391 surround sound during TV viewing. Surround sound is available for DVD, Tuner. Connection via HDMI Cable from the YHT 391 out HDMI to the HDMI #6 on a HDTV 1080p Sharp.
I havent received my system yet,but while reading the manul it says the hdmi cable only transmits the picture(i know i know hdmi supposes to transfer both)you suppose to hook up an dital or coaxile cable for the sound
Sep 13, 2009 | Yamaha YHT-390 Theater System
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
The HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Jan 10, 2009 | Yamaha HTR-6140 Receiver
Onkyo TX-SR605 hdmi output jack was damaged and needs replacing. A) Where can I get the part and how much for it? B) Does the replacement part require solder or is it a snap in type connection?
The hdmi output and inputs are on a modular circuit board that you only need a philips screwdriver to swap out. I need this board as well since I also have a damaged hdmi output jack but have not been able to locate the replacement board. If anyone knows where to look I would appreciate knowing.
Apr 25, 2008 | Audio Players & Recorders
114 people viewed this question
 Grubhead
Grubhead
