Problems on feeding paper into my new Epson SX125 printer. Hoe should sheets be positioned for successful feed and output?
Orbixx
  • 133 Answers
SOURCE: automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Posted on Sep 06, 2007
checkitright
  • 1362 Answers
SOURCE: HP Laserjet 1320 Paper feed malfunction
Solution,
 take out the tray
if you look on the bottom of the machine there is a metal plate.
in the middle of the plate there is a bump
turn the tray upside down and look at the bottom, there is a small hole with a plastic lever. it is probably broken.
when the tray is slid into position the lever hits the bump and releases the lifting mechanism.
replace that part or the tray. I can get you a new tray e-mail me at
pakapala@gmail.com
Posted on Oct 18, 2007
jamie608
  • 32 Answers
SOURCE: Paper feed feeding multiple sheets
The most likely cause of this problem is a paper feeder malfunction. Because you were not specific in the model you have, repair could be rather variable.
One plausible cause is the paper rollers have tried up. Normally when the small rubber rollers grip the paper, the friction generated by a properly moisturized feeder can grip a single sheet. If your rollers are getting dry, you can use some rubbing alcohol on a q-tip and rub it on the rollers. Make sure not to use isopropyl alcohol, that will cause the rollers to dry out even more. I've heard of people using WD-40, but I've never tried that. You would want the WD-40 to dry a while otherwise it will leave greasy residue on your nice white paper.
Another cause could be a small object (paperclip, staple, raisins) stuck in the paper feeding mechanism. Carefully inspect the feeder, comparing one side to another, and gently pushing on the movable parts to make sure they can move free. You don't want to push too hard or you could knock out a needed spring or damage the plastic gears.
Hope this helps!
Posted on Oct 16, 2008
worldvet
  • 859 Answers
SOURCE: Epson DX 6050 Paper feeding issues
I'm here to FIX your problem. I don't want to be helpful. I want to FIX your problem. If you will work with me, I will work with you until this is FIXED.
The paper not loading from one side is a problem with the pickup and feed roller on one side. This happens when rollers dry out and actually shrink as a result.
To resolve this, all we need to do is 'rehydrate' the rollers. There are solutions you can buy to do this and maybe it will come to that with yours. But, I've used this method below for years of working on Ink Jets since they first came out in 92.
Remove all paper.
Get a clean sponge and dampen it fairly well.
Now, you will want to repeatedly press the Paper Feed button while holding the damp sponge firmly against the pickup and feed rollers you can see while looking down your paper tray of your printer. You should be able to see these rollers quite easily.
The trick is to keep damping the sponge and pressing it against the rollers while pressing Paper Feed a lot of times. How many times? Well, this varies. But you will want to do this at least a dozen times on each side of the pickup rollers to start with.
Once, you are done with this initial attempt, you will want to give the rollers a chance for their surface to dry to the touch. Then, insert a full load of paper and press Paper Feed and see if your printer loads the paper correctly. If it attempts to load and does so better than before but does not quite finish, pull the paper out, its okay to do this, and rehydrate the rollers some more until the paper feed works as expected.
Let me know how this works out for you. I can direct you to a vendor on the internet to buy some roller rejuvenator later if its actually needed. I have found that you can do this trick with the damp sponge on an as needed basis from time to time and achieve the same result.
If, however this does not make any difference in your printers ability to pick up and feed paper then you have a mechanical problem and if under warranty you'll want Epson to fix it. If not under warranty you could have Epson fix it but you'd probably be better off getting a replacement. You will have to decided on that once Epson quotes a price to repair and replace the damaged parts.
Please use the comment text area below to communicate with me and ask any questions to explain something or ask a further question. I will receive an email alert and will get back with you as soon as I am able. This will depend on our time zone differences.
Regards,
Worldvet
Posted on Nov 09, 2008
SOURCE: Deskjet 1220c paper feed problems
Fix as promised... totally stripped the machine down today and a cleaned the Cam on the lifting gear and it works a treat now. To do this involves taking a lot of screws out inc the top opener, both sides and the front exit paper feed (three screws and two spindle holders).
Posted on Dec 31, 2008
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    Will not feed paper of any size. No jams ever.
    clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
    Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
    Epson CX7800 3 in one printer feeds mulltiple sheets.
    This is usually caused by a dirty or dented feed roller.
    The feed roller is the black wheel that has s flat side to it above the paper tray. Try using a Q-tip and some rubbing alcohol to clean it. Then give it another whirl.
    As with the ink on the paper. This is usually caused by leaky printheads. Epson printers are notorious for having the printheads die on them, but usually from the ink drying out. Check and see if the bottom of the printhead can be reached and cleaned by Q-tip or cotton swab. Give it a good cleaning using rubbing alcohol. Don't go over board as the alcohol will dilute the ink.
    Mar 28, 2009 | Epson Stylus CX7800 All-In-One InkJet...
    Epson stylus c68 paper jam
    Hi Guest.
    Turn your printer off and load a single sheet of paper. Move the rubber wheel to anywhere. Turn the printer on and watch what happens in the paper feed slot (in official Epson parlance this is the "automatic sheet feeder" or ASF). You should see the rubber wheel etc set into the correct start postion. Then press the paper feed button and watch again. The plastic "wall" behind the piece of paper should move forward, pushing the sheet into the rotating rubber wheel. This should feed the paper into the "ready to print position". If this doesn't happen, it means something has come adrift inside the paper feed system. To investigate this further requires the printer to be dismantled. Either take it to a technician, or if you want to have a go at doing this yourself, post a new comment to this effect and I will help you do this.
    Mar 17, 2009 | Epson Stylus Photo R320 InkJet Printer
    My printer no longer feeds in Epson Premium Glossy paper S041624
    Try to clean the paper pick rollers with a cloth, dam it with little water and try to hange the paper settings by going into printer preferances.
    Regards,  raj_p5983
    Jan 20, 2009 | Epson Stylus Color 1160 InkJet Printer
    EPSON R1800
    Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
    Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
    My Epson C 84 had something jammed into the paper feed and once the item (a blind pull from the window) was dislodged it will not fee paper or print. any words of advice?
    It seems likely that the feed mechanism has been dislodged or broken in some way.
    Look down into the place where the paper goes (the "automatic sheet feeder" or ASF) and you should see a fat wheel with a grey ribbed rubber facing. Place a single sheet of paper in the ASF and do a test print (right click the printer icon and select properties). Watch to see what happens in the ASF. The plastic panel behind the sheet of paper should move forward to push the sheet against the rotating rubber wheel, which should then feed the paper into the print position. If this is not happening you will need to dismantle the printer to investigate further.
    If you wish to do this, post a new comment to this effect and I will provide further help.
    Nov 10, 2007 | Epson Stylus C88 InkJet Photo Printer
    934 people viewed this question
    k24674
    jasbo
    jasbo
