Question about Nikon COOLPIX S52 Digital Camera
When i switch on my camera it shows "memory card
  • 747 Answers
There is possible two things that are preventing you from using the memory card first there is a small switch on the side of the SD card I'm providing a diagram to show you. Make sure the little switch is in the correct position.
Next and most probably the main thing is the memory card needs to be formatted to the camera it is being used in. Formatting some times called initializing prepares the memory card surface to receive camera data and picture files. Formatting should be done each time a new memory card is going to be used in a camera and after each time the picture files are downloaded to the computer.
If you have been using this card and only deleting the picture files what has happened is that there is a small file left on the card each time you delete after a time these little files clog the memory card to a point the card can not receive any new data. Formatting is the way to clear off all this impertinent data and start fresh.
Cheers have fun with your camera.
Posted on Mar 15, 2011
Memory card is write protected
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 17, 2012 | Nikon COOLPIX S6300 16MP 10x Opt Zoom 2.7...
Why is my camera stating write protect?
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 26, 2012 | Kyocera Finecam S3X Digital Camera
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
When i insert the memory card in my Kodak c143 east share then i displayed that " memory card is protected (reset switch on memory card)".
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 24, 2011 | Kodak EasyShare C143 Digital Camera
Camera shows error message saying "Memory card is protected (reset switch on memory card). This message does not clear when I reset the switch. Any suggestions?
The switch internal to the camera may be gummed up. But it can be easily "jogged" back open without opening the camera. You might try the toothpick or the tape fix listed in the troubleshooting steps of this blog article.
Jul 24, 2011 | Kodak EasyShare M552 Digital Camera
I inserted kinston 4gb card in my digital camera , while in the unlocked position of switch.But camera shows "memory card error" "card locked"
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus. The link for the steps is present in the related link at the bottom of the article.
  • Read more: http://wiki.answers.com/Q/How_do_you_remove_write_protection_from_a_mini_SD_card#ixzz1Fvsnj1XE
    Mar 07, 2011 | Kingston 4GB Secure Digital High Capacity...
    Whenever I tried to make s shot it says "protected
    There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
    Nov 22, 2010 | Sanyo Xacti VPC-T700 Digital Camera
    Camera shows a "Write Protect"
    SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
    Nov 14, 2010 | Olympus EVOLT E-410 Digital Camera
    When I turn on the camera it is showing "Card
    Take a look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
    If that doesn't work, try a different card.
    Oct 29, 2010 | Canon PowerShot SD1000 Digital Camera
    "Protected Card"
    May 08, 2009 | Fuji FinePix S7000 Digital Camera
    Nikon COOLPIX S52 Digital Camera Logo
    56 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Ric Donato
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
