Question about Toshiba Televison & Video
THERE IS A YELLOW SHADOW IN THE LEFT SIDE OF A BODY WITH ANTHER BLUE SHADOW IN THE RIGHT SIDE OF THE SAME BODY PLEASE ADVICE ....
  • Toshiba Master
  • 2,098 Answers
Hi alalfaraj,
If the symptom didn't cure by convergence adjustment through the remote control, this is an indication of faulty convergence board inside. You may replace the convergence IC's and some of the resistor around because its already gone bad. You may also replace the entire convergence board for your convenient. If the board replaced with new one, your unit will back to normal again. Also, consider bad solder joints in that area, it will do the same symptom like what you've encountered right now. Find it first and re-solder. If you don't have necessary tools and test instrument and can't do the job yourself, I would advise you to look for a qualified technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 15, 2011
I have small blue dots and a yellow shadow in the middle of my screen
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
Let me know if you have questions.
Dec 02, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
Dec 16, 2010 | 1996 Jeep Grand Cherokee
Stereo wiring color code for a 94 dodge shadow
1994 Dodge Shadow Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 5? x 7?
Car Audio Rear Speakers Location: Side Shelves
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
Nov 14, 2010 | Dodge Shadow Cars & Trucks
Porjector
Hi there
Is it a LCD or DLP ?
First try using a different cable. If the problem stil occurs this might be a faulty Mainboard - which would need either repair or replacement.
Does the discolouration show in the startup screen as well ?
Apr 17, 2008 | Office Equipment & Supplies
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Yellow and Blue shadow on left side of screen
Blue convergence off = needs convergence IC's replaced =
Would you like step - by - step how to ??????
Nov 07, 2007 | Toshiba 51H84 51" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
