Question about Ovens
I have a Baumatic BT2450ss and the bottom base element needs replacing, i have bought one but need advice on how to fit it?
5 Suggested Answers
  • 1462 Answers
SOURCE: light
easy. unscrew bulb cover then unscrew bulb. switch off at wall first.make sure you use a heat-proof bulb to replace
Posted on Apr 24, 2007
KOakaKO
  • 135 Answers
SOURCE: Baumatic b180 oven
The oven cabinet is likely built for several different models, which means that the case could have been built with an extra hole or two that aren't used on your model. This a normal manufacturing technique for mass-product factories. I see from the Baumatic website that several of their models do use a meat thermometer probe, but even if you bought a probe you couldn't use it your oven. Your model doesn't have the correct circuit board and control panel that the oven needs to use the probe. In any case, if you need to order parts from the manufacturer or would like a downloadable Owners Manual for your model, they are available at this website link: http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B185SS-B Hope that helps! ;)
Posted on Aug 06, 2007
barkencoa
  • 3463 Answers
SOURCE: Fitting Base Element for SMEG DO4SS-5
Some fan assisited ovens do have a base element, some do not.
If there is no heat at all in the oven , then it is safe to say that the fan element has gone, replace that first, if it does not reach correct operating temp, then it probably has a base element as well that needs to be replaced, this would mean removing outer oven panels to access it.
Plz rate my soution.
Thanks.
Posted on Jan 18, 2009
barkencoa
  • 3463 Answers
SOURCE: I need to replace faulty
As long as it is the correct wattage, then you should not experience any problems.
Posted on Jan 08, 2011
Floor element not working have got new element need instructions on fitting
Hi
Please check this video for element replacement:
Hope this helps...please post back for further assistance.
Daniel
Mar 06, 2011 | Baumatic B205SS Stainless Steel Electric...
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
The fan oven is not heating up. The fan appears to to be operating and the element for the grill heats up . I had the oven element replaced over a year ago.
If the fan is working o/k, but there is no heat, then it is more than likely the element that has failed again.
The fact that you had it replaced a year ago, does not mean tha it will last a long tiime, it is quite common for them to fail in a relatively short space of time.
Take my advice and fit a new element.
Thankyou.
Dec 03, 2009 | Baumatic Ovens
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
Replace Baumatic oven base element
You would have to figure a way to get those screws out.
I'm not a mechanic, but I did have to replace an element for a friend. Is there some way to use something with a magnet that it would attach to in order to remove the screws?
Jun 14, 2017 | Ovens
Baumatic 1870ss steel electric oven
sounds like your element is not wired in properly or its faulty get someone to look at it
Aug 28, 2007 | Baumatic B187 Stainless Steel Electric...
Baumatic b180 oven
Aug 05, 2007 | Baumatic B180SS And B60SS (Bundle)...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
