Question about LG Washing Machines
I have a LG direct drive wahing machine and its flashing IE cant find manual what does it mean please help!
    Sergeant:
    Novelist:
  • 196 Answers
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. Check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. If clogged, water will not flow through these filters into the washer. Disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. i have a LG direct drive wahing machine and its - wm_inlet_filter_removal(1).jpg If this doesn't work then you will need to change the water inlet valve by removing the top panel.
Posted on Mar 15, 2011
HOW DO I STARTS MY WASHING MACHINE AGAIN CAUSE IT ALWAYS `IE` ERROR EVEN I ALREADY CLEAN THE FILTER,CHECK HOSE,THIS ERROR HAPPENS WHEN SOMEONE USE IT MANUAL WHEN NO WATER IN SERVICE,I MEAN HE MANUALLY
The IE or E1 error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
If you are trying to use the machine manually, there needs to be enough water in the machine to tell the level sensor when to switch off the water inlet solenoid valve. Failing this, the machine will only show IE (Inlet Error) and refuse to work.
Feb 15, 2015 | LG WD-1070QDP 7 Kg Direct Drive Washer
My LG direct drive dishwasher is giving me an IE or 13 error
Hi, according to the owner's manual on mine, "IE ERROR" means it's a 'water input error'. You have to check for a kink or clog to the water hose running to your machine. Once you unclog the water hose, you error code will disappear.
Jun 21, 2011 | LG Dishwashers
LG washing machine direct drive when i put it on it washes and goes down to 9 mins then stops, sometimes an error code comes up UE? CAN U HELP PLEASE
It means Unbalanced Error, it means the machine cant balance the load during the spin cycle, normally happens if there is too little a load i.e 1 or 2 things or overloaded. It is designed to protect the bearings. If it happens with a normal load try stopping it and re-arranging the load by hand and putting it on a spin only cycle. Hope this helps.
Feb 28, 2011 | Washing Machines
Whirlpool AWM1019 wahing machine - what does AH code mean on display. Will do all the right things but wont move on ie wash and drain but then wont rinse. On start of any programme starts to fill then AH...
Hi! I checked both the inlet pipe and the rinse drain pipe. Both are fine. What next. The machine gets to 26 and then starts beeping. It is driving me absolutely crazy!!
Jan 23, 2011 | Whirlpool Washing Machines
I have an lg direct drive 9kg washing machine and the water does not empty from the drum it flashes 03
03 error means drain pump is blocked or broken check the filter first before having someone out.
Jan 10, 2011 | LG Washing Machines
LG Driect drive what does DU mean on the washing machine
Are you sure the error is DU?
That DU is fault of the main board and it will need to be replaced.
Apr 10, 2010 | LG WM-2277HW Front Load Washer
Waher showing LE and not wahing
if your machine is an LG , then le code means your motor senor or motor is faulty.if u r confident change sensor first.is it a top loader or front loader?the sensor is attached to motor. if u would like more help please reply. if u r getting service company 2 do job, ring around 4 prices on changing sensor or motor. this should save u money
Apr 06, 2010 | LG Washing Machines
What does ie error code mean
Inlet error
Hoses backwards,clogged,kinked, and my personal fav: water bill not paid.
Feb 26, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
WHAT DOES ERROR CODE IE MEAN ON LG DIRECT DRIVE WASHING MACHINE?
IE = Inlet Error. Check for plugged screens where hoses screw onto machine (especially the cold side). Other possibilies are kinked hoses, valve shut off where hose goes to washer, or a bad inlet water valve (the part the hose screws onto), or even a bad control board or bad wire to water valve.
Nov 27, 2009 | Washing Machines
Washing Machines Logo
313 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
