Question about Coby 5.1 Channel DVD Player with Home Theater Speaker System System
Parts I need the part (small motor) that moves the cd into the eye Colby model DVD-925, s/n 0935000677 no disc error, have determined this part needs replacing thanks
Found out from manufacturer the only way to replace motor is to pull one from a compatible system, spare parts unavailable.
Posted on Aug 02, 2008
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Panasonic Portable dvd/cd player model #DVD-LS90 The player turns on and tries to read the DVD. However, it no longer spins so the DVD cannot be read.
Two possibilities:
  • the laser eye (lens) is dirty, weak or defective. The unit no longer can sense that a disc is present and therefore will not initiate servo motor engagement. Pls try cleaning;
  • the spindle motor is weak or defective. This might be of additional information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Panasonic Televison & Video
Error code H03.
To my knowledge Panasoni Error Code H03 indicates mechanical failure, more specifically, the traverse servo motor. Simply stated, the eye cradle could no longer slide back and forth along the slider bar. Corrective measure requires cleaning and application of appropriate light lubricant. Vaseline oil would do for the time bieng. Pls refer to the diagram below.
Aug 09, 2008 | Panasonic DVD-LS850
I have a portable dvd player ( model pvs 3377). Worked fine until last night when i tried to play a dvd. When I inserted the disc it said LOADING and after a few seconds stopped and said NO DISC. Can't...
My first solution would be to clean the glass laser eye with cotton swab and rubbing alcohol. If the player is self-fixable, that always works. If the cleaning does not work, than that means the eye motor or timing is off. If it is off, than it is due to a burnt out capacitor on the system board. THIS IS A VERY COMMON PROBLEM IN ALL PLAYERS. They will all eventually do this sometime in it's lifetime. If the cleaning does not work, than it is time to replace it or have it repaired by a qualified electronics repair technician. They will have to test the motor and all capacitor and components to determine the cause of the error
Apr 30, 2009 | Digital Audio Electronics - Others
Disc read error
Hmmmm, Then poissibly the motor might have a need for servicing. Because by the sounds of it, the motor isnt moving quite right inside the system. I ran into this problem with my PS1 and PS2's that i have had over the years. Motors can wear out over time and use. If your like my friends, they go through a new PS2 in a year flat, because it is used 20 to 22 horus a day by 3 different people. So yeah, they use theirs very well.
Back to subject. Anyways, if the motor is not actually doing much but clicking, it sounds like there is an Obstruction in the way of the spin. Meaning, its not getting its complete rotation every whatever amount, so it will not read the disc. The motor also has to be able to move back and forth to read the disc as you play it and if that motor goes, than you rarely can play a game all the way through.
There are usually a number of computer stores (small time) that offer repair services for a price. They can usually order the small parts and Sony lets them install those replacement parts, because like all big companies, it takes a lot longer to get things done because everyone goes there first.
When searching for a store that can help, be specific in questioning. You need to ask directly if they have any employee's who know how to service PS2's
Oct 29, 2008 | Sony PlayStation 2 (PS2) Console
CD Player problem
Most DVD players that would not play a disc even with a known good disc inside signifies that the llaser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components; and/or
4. dirty, dried up lubrication, defective spindle motor.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded;
5. relube, clean as necessary
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 10, 2008 | Audio Players & Recorders
Cd player reads disc error
maybe you need to change the optical eye now.
but first try to adjust the variable resistor/trimpot resistor.
try this options to your player.
(TIP)
if using a cd/vcd/dvd products, we only should play a cd/vcd/dvd dics without a bad scratches. the scratches are making the optical eye worn-out easily.
Jan 28, 2008 | Tascam CD-A500 CD Player
Bad Disc Error
TAKE A LOOK ON YOUR LENS MAYBE IT WAS NEED A CLEANING CLEAN IT W/A COTTON BUDS CAREFULLY OR OBSERVE CENTER MOTOR IF ONCE YOU ON YOUR VE700 IF IT SPIN ALITTLE BIT IT REQUIRED YOU TO CONCENTRATE ON LENS AND MAYBE YOU TO REPLACE IT
Mar 25, 2007 | Audiovox VE700 7 in. Portable Television
Coby 5.1 Channel DVD Player with Home Theater Speaker System System Logo
109 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
