Question about Dell M410HD Projector Projector
Hello, please tell me how to flip the image upside down. I ceiling mount my M410HD and I can not turn the image 180 degrees. Thank you, Mircea
  • 3,400 Answers
Go into projectors menu, and you'll find sub menu "display" and it will give you options front, rear, etc and choice front, ceiling
Posted on Mar 15, 2011
  • 6 more comments
  • mircea_carab Mar 15, 2011
    Thank you very much, but I have under "Display" only ->Aspect Ratio
    ->Zoom
    ->Zoom Navigation
    Strange...
  • Mical Caterina
    Mical Caterina Mar 15, 2011
    You might have to get into extended menus - "projection" . I'd search it google (but I'm on phone currently and away from computer)
  • mircea_carab Mar 16, 2011
    Unfortunately, there is no extended menu. I Googled for this issue and I found that I am not the only one asking for a solution for this problem. If there is nowhere written that this projector is able to flip the image, perhaps it can not do really do this. Thank you, Mircea
  • Mical Caterina
    Mical Caterina Mar 16, 2011
    My apologies, I just downloaded your manual and I'm also amazed that this model has no extended menu for overhead mtg. You might call Dell (included w/link)
    http://support.dell.com/support/edocs/ac...
    (800.999.3355)
    np I'll do so. Regards.
  • davyo_x2000 Jun 20, 2011
    HAVE YOU FIND ANYTHING? I HAVE THE SAME PROBLEM TOO
    HELLO ! HAVE YOU FOUND THE PROBLEM?
  • mircea_carab Jun 21, 2011
    Hello. I gave up. I bought a ceiling mount kit which looks like a plate on which I simply put the projector in it's 'normal' way. Thank you for your support.
Will turning your television upside down damage your television?
No it will nNo it is not. In fact some televisions are designed with this in mind. Usually this is done with smaller televisions that will be mounted. On those televisions there will be a picture flip or reverse image/invert image setting. I have spoken with bewildered seniors with upside down pictures and advised them to simply press picture flip until their image is right side up again. There are some customers that mount their televisions in bathroom mirrors or on the ceiling, under kitchen counters, and etc. who have found this to be most helpful.
Jun 13, 2011 | Televison & Video
I mounted the projector on the ceiling and need to flip the image
ok go in the main menu u see 4 windows under on eof the options flip throw the windows to get it to go right side up ok in menu settings on the sony ok
Feb 02, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
When I attempt to use my USB2.0 UVC VGA WebCam, the image that pops up is upside down.
There should be a setting in the camera software, that sets the mirroring or rotation of the image. Play around with the mirror-flipping options or the rotation factor to get the image right. If it's filpped upside down, a Flip Vertical should do, or a 180 degrees rotation.
If you find this post helpful and informative please vote with a Thumb Up. Thank you.
Jan 19, 2011 | ASUS K50IJ-C1 Notebook
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Mustang projector mount required mounting projector upside down...
You may have figured it out by now... From the remote, you go into the menu and find the setting "Display Image" and the option is "Ceiling".
Dec 26, 2007 | Panasonic PT-AE700U Multimedia Projector
Angle of projected image
Hi there
No this can not be changed , the PB6100 was actually designed to mounted upside down in your ceiling and therefore the lens is 28-30 degrees upwards when projected on a flat surface.
Flip it upside down and you'll see what I'm getting at.
Oct 07, 2007 | BenQ PB6100 Multimedia Projector
Image won't flip when the lcd panel is fliped to 180 degree i.e when i flip the lcd panel towards the lense to do a self shoot the image, instead of appearing stright appears upside - down
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. most probably the switch has worn out.
Aug 16, 2006 | JVC GR-DVL120 Mini DV Camcorder
Dell M410HD Projector Projector Logo
505 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
