Question about Dell M992 19" CRT Monitor
I've got a LG flatscreen monitor and a projector as my extended display,when i play my videos i see flyback lines on my screen,my pc is brand new
  • 3,400 Answers
First check resolution settings make sure PC and monitor are set to same. Also make sure cable(s) are tight.
Posted on Mar 15, 2011
Lg flatscreen monitor
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Computers & Internet
I have a dual display with a Samsung digital LCD flatscreen and LG analog LCD flatscreen running on WinXP with a nVidia GeForce 8400GS video card. The video card is new - the old card (which was hooked up...
Hi
I'm not sure what you mean by VGI. I will assume you mean VGA (Analogue - D Shaped with 15 pinholes).
When pixels or line of lixels fail on a monitor, they usually fail in spots or in a vertical lines due to the design of the matrix.
Since both monitors are sharing a single cable and the graphics card is a new one, the fault automatically isolates itself to either the monitor or its VGA connector.
Check that none of the pins in the end that connects to the faulty monitor are bent and/or touching one another and shorting.
Then try changing the resolution of the graphics card itself and test the monitor's performance at various settings to see if the resolution seeting is straining against the limits of the monitors range.
Right click on open space in the desktop > properties > settings > click and hold the slider scale step by step, up and down the scaled to test the monitor > apply > ok > test for a reasonable period > reset.
Also test the monitor with a single VGA cable to another computer (even a laptop, using the Fn key + external monitor function key).
Thses tests should tell you if the monitor is failing.
I hope this helps.
Aug 24, 2011 | Computers & Internet
Using the splitter i can not get windows 7 to recognize the other monitor and enable multiple monitors
Hello there,
As you've said you're using a display splitter, the result will be identical screen on both monitors. splitters main function is to split VGA signals into N of outputs. where N=number of outputs. no matter how many monitors you attach to your splitter, the windows only recognize monitors attached directly to your video card. Windows requires a video card that has two or more output VGA or DVI outputs to get second extended monitor or display link device.
If you're video card has two outputs follow the instruction below.
1. plug the VGA or DVI other cable on the unused port. 2. power on the second monitor. 3. right click on the desktop, click screen resolution.
4. click the display in gray, Multiple Displays: it depends on the user.
5. I selected extended display. 6. apply and ok.
This spreads your desktop over both monitors and lets you drag items between the two screens. This is how most people use two monitors, and it's the default setting for desktop computers. you can use your mouse to grab the title bar (the top portion) of a window and drag it to your new display.
Hopefully this information is helpful. Thank you for using FixYa..
Jul 17, 2011 | Computers & Internet
We are tring to hook up our projector to our laptop.
Nice! Putting your *generic* laptop on a *generic* projector can look awesome for movies, gaming or just surfing. It all depends on the connection you use.
To make the connection, you need to choose a cable that both the *generic* laptop and the *generic* projector support. Here's the common ones, in order of awesome (most to least):
HDMI,
DVI,
RGB/VGA,
Component,
S-Video,
Composite
Of course, with adapters you can basically connect any of these types into any other type.
So now you've connected them both, but there's no picture! Don't fret; there's still more to do. First, make sure the *generic* projector is on the right input channel. Use your remote or the buttons on the *generic* projector itself to turn to it.
Then you have to set up the *generic* laptop. Many different laptops these days will let you just press the "FN" key along with the "F5" key to switch to projector mode. Pressing it again will switch which type of mode it's in (duplicate, extend or projector only). You can also do this in your computer settings, though.
On Windows 7:
"Windows Key" + "P".
-or-
Start Menu > Control Panel. If Control Panel is in Classic View, go to Display > Adjust Resolution(it's on the left side toolbar). Otherwise, click on "Adjust Screen Resolution" under the Appearances and Personalization category. Click on the second monitor, then make a selection from the "Multiple Displays" option.
On Windows Vista:
Start Menu > Control Panel > Appearance and Personalization > Personalization > Display Settings > Monitor (it's a tab). Select the second display from the Display drop-down menu then check the box for "Extend my Windows desktop onto this monitor"
On Windows XP:
Right-click the desktop > Properties > Settings (it's a tab). Select the second display from the Display drop-down menu, then check the box for "Extend my Windows desktop onto this monitor"
On Mac:
It's already set up! Seriously, it's plug and play; very awesome. To change the mode (mirroring/duplicate, extended), goto Display Preferences > Arrangement.
On Linux:
I have no idea, so I Googled it for you. You're welcome.
There! Your *generic* laptop is now connected to your *generic* projector. Enjoy your gaming/videos/web browsing/etc!
Mar 22, 2011 | Video Game Consoles & Games
I have a problem with displaying power point presentation
Hello, Chris.
I'm not certain if this was already tried, but here goes:
If you look at you keyboard function (F) keys, you'll see a symbol or the words "CRT/LCD". On my laptop, it is F8, but could be different on yours.
When you connect an external screen to your laptop, if the laptop information doesn't show on the external screen, press your Fn key plus that function key with the symbol or words.
Normally, when you press once, twice and three times, you toggle through various options: your laptop screen only, your external screen only and both screens.
Hope this helps.
Nov 10, 2009 | Acer Aspire One PC Notebook
T30 cannot connect to projector/external monitor on windows 7.
You can connect your computer to a projector to give a presentation on a large screen.First make sure the projector is turned on, and then plug the display cable from the projector into a video port on your computer.
Then press Win Key+P or run DisplaySwitch.exe and choose your preferred display.
Note:1.You can use this same procedure to connect your computer to a monitor
2.This will have no effect if you’ve only one display connected
Nov 09, 2009 | IBM ThinkPad T30 2366 Notebook
700e Lg crt monitor problam power on eht on but not display
The normal crt monitor have a demo display when you unplug the vga cable to PC like this image below.. fd6b6b9.jpg
Note:
If the crt monitor green LED light steady and heater beam have light, the horinzontal and High Voltage supplied to tube is completely good. If you encountered this problem just focus on video section of crt monitor. But before you start... find the flyback transformer behind this they have two controls screen & focus. After you found it plugin the monitor use plastic precision or small screw philip driver for safety to high voltage at horizontal area choose screen control rotate it to clockwise direction follow this....
5b5166c.jpg If the display responses or from dim to lighter 100% you have a problem to ABL find this at the bottom of horinzontal section near at flyback transformer pins trace the line of ABL for dried solder, open resistor if nothing happen find the Video IC at chroma section and replace it. follow this...
3c6e89c.jpg For LG & Redfox you found LM1269NA Visit this site for seaching semiconductor matches www.alldatasheet.com Good luck.
Check this site for searching semiconductor
Aug 12, 2009 | LG Studioworks 700S 17" CRT Monitor
LG Monitor Unable to Correctly Detect VGA Input
the problem is not the monitor.To be able to correctly set a dual display mode you need to configure you video card to do so. This is accomplished in your video card's control panel. There are various modes:
Clone: it simply clone the screen you'll have the same output on both monitors.
Extend: this will extend your desktop and make it one big screen.
theres another mode to show video only on one screen while the other display regular desktop activities you'll have to experiment.
the procedures for doing this varies depending on you video card: ati, nvidia, or Intel.
May 08, 2009 | Computers & Internet
Macbook & Projectors
Hi there
Yep, sounds like the machine thinks it is an additional monitor. So you can run it as that but the mirroring does not work. So the mirroring works with your own projector?
There are a couple of things you can do. Try connecting the projector and power it up when you machine is off and then boot your machine up. If the mirroring still does not work open up your display panel look under arrangement. You should then see two displays. One will have a red line around it. That is your laptop. In the display panel you can then drag the second display over your display and that should have the same effect as mirroring.
That's the low tech first try.
Sep 19, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Cannot display image on a proector using Lenovo laptop
Ok.I got your point.Actually you're in extended mode.
Once you connect you can have 2 types of output to your projector.
1.Clone mode--> make everthing look the same
2.Extended mode--> have another new space for you to use.
** in extended mode you'll have a background of your desktop.you can drag any running program to that space.
How to setup clone and extended mode
1.Click start-->Settings-->Conteol Panel-->Display
2.Under Display Properties window click the last tab name settings
3.Under display select you 2nd monitor
3.Below Screen Resolution you should be able to see a checkbox "extended my windows destop on to this monitor"
please check this box for extended mode or uncheck it incase you won't to use clone mode.
takecare.
Apr 28, 2008 | Computers & Internet
Dell M992 19" CRT Monitor Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
