Question about HP LaserJet 1200 Printer
Paper jam in HP 1200 printer - HP LaserJet 1200 Printer
    Genius:
  • 1,622 Answers
Hi,Make sure you got every single piece in there, and if you can't get it to work, just hard reset it. Unplug it from the wall wait 5 seconds, plug it back in. Should be good as new.
The LaserJet 1200 has two paper inputs, a regular paper tray and a priority input tray that is used for envelopes, labels and transparencies.
Paper jams rarely happen with the HP LaserJet 1200. If you can see paper sticking out of the input or output tray, try to remove it gently. If you encounter resistance or if the page tears, turn off the lights in the room to avoid exposing the toner to light. Open the toner door, which is above the paper tray, and the output door, and rotate the green levers down. At this point, you might be able to remove the jammed paper. If not, remove the toner cartridge.
Grasp the page in both hands and gently pull it free. Replace the toner cartridge and close the doors. The cartridge and the levers will slide back into place.
Hope that helps..
Posted on Mar 15, 2011
Hp laserjet 1200 printer.. i have a paper jam.. i've looked all over to see where i access the roller to get the paper out and i can't find it!
Paper Jammed can be found inside the toner cartridge compartment.
It can also be found in the paper feeder.
It can also be found at the back of the printer (if it can be accessible or can be open).
It can also found in the toner cartridge itself.
Check this areas to find for a paper jammed.
Jun 08, 2011 | HP LaserJet 1220 Printer
My 1200 printer had a paper jam with envelope we
me pasa lo mismo, pongo una hoja, la toma, y la saca por arriba, como queriendo sacar la hoja trancada, aunque no termina de escupir toda la hoja, la deja 1 pulgada adentro y se la tengo que sacar de pesado, y la luz de paperjam sigue blinking
May 17, 2010 | HP Business InkJet 1200D Printer
Paper keeps ripping on the side on normal one sided printing. Duoble sided printing paper just rips up and jams.
sounds like some tron parper was stuck inside and has contributed to more paper tearing. First check for any paper jams, and check inside for and broken or damages items, causing paper to tear.
Nov 27, 2009 | HP Officejet Pro K8600dn - - colour -...
HP LaserJet 1200 Series PCL 6 PAPER JAM HOW TO RESET PRINTER
IF THE PAPER JAM IS REMOVED THE PRINTER WILL RESET BY ITSELF.CHECK TO SEE IF THE PAPER SENSOR ARM IS NOT STUCK
Oct 02, 2009 | HP LaserJet 1220 Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
Paper jam
Make sure you don't have too much paper inserted, make sure its a little loose, if you push it too thighly it wont come out correctly.
Let me get you instructions for clearing that jam in a moment.
Oct 28, 2008 | HP LaserJet 1200 Printer
Paper jam
here try this guide to clearing Jams supplied by HP
Clearing Paper Jam Guide
I hope this clears your problem :)
Apr 02, 2008 | HP Photosmart C4180 All-In-One InkJet...
Hp laSERJET 1200 PAPER JAM
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
HP Business Inkjet 1200
sure..there must be something underneath in the tray or paper slots..check carefully..I use a pen light in a darkened room..the white shows clearly then.
Oct 16, 2007 | HP Inkjet 1200dn Printer
HP LaserJet 1200 Printer Logo
281 people viewed this question
Seeker5211
Seeker5211
