I have a LG intellowasher 7.5kg WD-8016c. The door handle broke and although I have a replacement handle need a visual on putting it together
  • 8 Answers
SOURCE: I bought my LG Intellowasher WD-8016C second hand
Manual suggests Exterior with household detergent. Do not use methylated spirits, diluents or similar products.
For internal, dry around the washer door and run washer through a complete cycle using just hot water... and repeat if needed.
Not sure about mould.... not in manual.
Posted on Feb 14, 2010
SOURCE: door wont open on LG WD-8016C
mine either. The handle seems to break easily. Try getting a butter knife and pushing in from the left hand side, this will undo the latch.
Posted on Aug 09, 2010
  • 713 Answers
SOURCE: where is the lint filter
Hi just read your posting.I have worked on these machines before and I don"t recall this model having a lint filter.I know it has a drain pump filter and filters in the inlet hoses.Are you getting a lot of lint on your clothing?I will endeavor to find out definitively whether your model of machine has a lint filter and I will re post the solution.
Posted on Sep 18, 2010
  • 298 Answers
SOURCE: operating manual for LG intellowash
you can go to appliancerepairplanet.vstore.ca to get a sevice manual on that model.
Posted on Dec 22, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: My LG intellowasher 7,5kg WD-
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
LED display models LCD Display Models
Step 1: Check the drain pump filter.
Step 3: Confirm that the washer is leveled properly.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
NOTE: Perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Posted on Dec 25, 2010
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
Lg intellowasher wd 10160f
Check the Lid Switch Assembly with an Ohm meter for continuity, these switches are a common problem. Replace the switch assembly if faulty.
Mar 18, 2014 | LG Washing Machines
Where is the lint filter for the LG Intellowasher 7.5kg (model WD-8016C)?
Sep 18, 2010 | Washing Machines
I have an intellowasher made by LG WD1023C I have
This means -Child Lock trying to solve the problem myself- I think by pushing 2 buttons together... but which ones?
Aug 16, 2010 | LG WD-1080FD Front Load Washer
Door wont open on LG WD-8016C
Jan 31, 2010 | LG Washing Machines
I bought my LG Intellowasher WD-8016C second hand and have no manual. Does it need to be washed occasionally with washing sda. There is a bit of mould around the seal. How do I clean this.
Nov 02, 2009 | LG WD-16115FD Front Load Washer
I can't open the door of my washing machine it is a front loader lg intellowasher 7 kg wd8013c please help asap
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Oct 05, 2009 | Washing Machines
Top loader door wont open
Something has caused the washer to not release the door. Is there an error code that is flashing (FE?). A locked door can be due to too much water in the basket, suds causing false water detection (should be using HE), or perhaps the drain is clogged.
If you are sure that the water is not going to spill out on floor, then you might be able to get door open by unplugging the unit and waiting a few minutes (mine took an hour) for the electric lock to release.
Sep 15, 2009 | LG WD-16115FD Front Load Washer
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
