Question about Epson Stylus CX6600 All-In-One InkJet Printer
When i press print, the goes through the motoins but nothing is printed on the piece of paper, and there is plenty of ink the catridges, any ideas??????
  • 51 Answers
Hi with your Epson machine normally its the print head that has dried up and the ink is not able to get on to the paper have you used the head cleaning on the machine? this can help and some people claim that using head cleaning liquid works (I have not found them to be much use)
if you have tried all the above then its down to replacing the print heads and this is not for the DIY person and in the Uk it usually not an economical repair
sorry Ian
Posted on Mar 15, 2011
Printer has ink but not printing at all. Paper goes through the printer but nothing on the paper.
Remove your color/black catridge and rub their head with toilet paper/soft paper neatly until the ink stain on the paper. On the same way it also caused by ink over flow. To solve the ink over flow rub it carefully.. thanks
Aug 25, 2011 | Canon Pixma iP2600 Photo InkJet Printer
HP842C continues to print with nothing on the paper but a line across the top of letters and numbers. The orange light will not go off. There was a paper jam which I removed then paper continued going...
Check your Catridges, they might be dried up if new, or empty, Remove them shake them to feel a presence of ink or tap them on a piece of paper to verify if ink will comeout if not then they are empty and need to be replaced they they have a bit of ink you need to shake and try printing again if this persists change the catridges, also make sure that the Printer is Clean, verify the Catridge Carrier for any dry ink deposits.
Dec 03, 2010 | HP DeskJet 842c InkJet Printer
My fax won't print, neither faxes nor copies. The paper goes through & it makes sounds like it is printing but nothing on the paper. The machine says the ink level is 6/8. I "aligned" and...
Though the ink level it said was "6 / 8", when I removed the cartridge to examine it looked bone dry empty to me. I replaced the ink cartridge. It works fine, and reports the ink level as "8 / 8".
Sep 09, 2009 | HP 1040 Plain Paper Inkjet Fax
Black not printing properly
Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer........
Good Luck
May 07, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printer problems
In this case what i would request u to do is.......
Know insert both the catridges inside the Printer..........
Good Luck.............
Apr 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Speratice printing
Good Luck
Mar 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer does not print
Now try to Print.........
This Should Work.........
Jan 23, 2009 | Epson Stylus Photo R200 InkJet Printer
Printer not printing
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Unplug the Power Supply from the printer....... Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button.......... Now the Printer will ask for the Date Time and Country Language......... Set everything up...... Now try to Print i am sure it should work.......... Good Luck............
Jan 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
CX6600 prints black lines through out documents
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Now try to Print it should work fine.......... Still same Problem Catridges Defective......... Good Luck...........
Jan 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
LexmarkX1240
sometimes the print heads will become blocked. Take the catridges out and put a piece of toilet paper across the head and see if ink bleeds through. if not try moistening some kitchen paper and gently cleaning the heads.
Nov 13, 2007 | Lexmark X1240 All-In-One InkJet Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
