Question about Microwave Ovens
Can you help with P.N.8065710 Flat Belt for Dryer OPTIBELT-RB-7PH-1970 ASKO CYLINDER Quantity 3 . From Hansens Kitchens 306 Fulham Road Chelsea LONDON SW10 9ER Please may I have Price availability and delivery charge to London. Thanks Michael Beatty.
    Brigadier General:
  • 8,909 Answers
Why not tyr www.espares.co.uk for belts.
Posted on Mar 15, 2011
Timer sounds getting quieter, can no longer hear them
timer audible tones are generated by a Piezoelectric sounder, usually found on the rear of the button/control pcb. Busy commercial kitchens can generate enough particulates in the air to clog this device over time, a strip and clean with alcohol applied with a small art and craft type brush might be all that's needed.
Jan 17, 2016 | Microwave Ovens
Rival rgst902 microwave. Door won't open.
verify that door is perfectly aligned with frame edge , sometimes in busy kitchens the door gets bumped and it no longer aligns with frame , if one forces it shut the mild spring that pops it open cant overcome the friction of frame hitting and it wont open requiring one to "HELP" it to open while holding down open button , look at latch carefully when open to see if any parts look bent or "not quite right "
Sep 17, 2015 | Rival Microwave Ovens
My dryer has started blowing cold air ?
The heater section is located behind the drum and consists of resistance wire coils suspended in ceramic insulators. The heater section provides the heat to dry your clothes. The GE/Hotpoint dryer has two coils; one for low heat and both for high heat. If your dryer's performance is unimpressive in the high heat settings it may have lost one set of coils and if you get no heat, you may have lost them both!
Procedures for Gathering Confirming Data
  1. Disconnect the power cord and move the dryer far enough away from the wall that you can tip the top up and it will stay there.
  2. There are screws holding the top of dryer down. Use a Torx #15 screwdriver to remove the screws. Lift the top up and swing it back against the wall or whatever is behind the dryer.
  3. Verify again that the power cord is unplugged.
  4. Examine the high limit thermostat on the top of the heater shroud behind the drum. Check for continuity through this thermostat. Go to the thermostat section for further fault verification and replacement information.
  5. Locate the 3 insulated studs and check for continuity between them. Put your ohmmeter in the lowest resistance range and measure the resistance between the three heater element terminals. If you read 18 to 20 ohms, the heater element is OK. If your meter doesn't move, the coils may be broken and you need to proceed on to their replacement. If you don't have an ohmmeter proceed on to the replacement procedure where you will remove the drum and you can examine the coils for broken heater wires.
Tools Required
  • An ohmmeter would be nice but is optional
  • 5/16 inch nut driver
  • No. 15 Torx screw driver
  • Wire cutters are handy for getting the old coils off and needle nosed pliers are handy for getting the new coil wires on the terminals
Parts Required
  • GE dryer element WE11X260 coil kit. I recommend replacing both coils even if only one is open.
Procedures for Replacing the Heater Coils
  1. If you have skipped the data gathering steps above, unplug the dryer, disconnect the dryer vent and pull the dryer far enough away from the wall to get behind it.
  2. Use a 5/16 inch nut driver to remove about 10 sheet metal screws from the rear access panel. Remove the panel and slide it down the power cord to get it out of the way.
  3. Make a little drawing of how the belt is routed around the idler pulley and the motor pulley. Reach in and relieve the tension on the belt by moving the idler pulley away from the belt. Slip the belt off the motor pulley and idler pulley.
  4. Locate the metal plate on the back of the dryer behind the drum. Use a 5/16 inch nut driver to remove the screws and then the panel.
  5. Use a small screw driver to pry the e-clip off the end of the drum shaft. Keep a finger on this e-clip as you ease it out or it will fly away and you will have to hunt for it. Carefully remove the three washers on the end of the shaft. The drum is now free to slide out of the rear bearing.
  6. Use a 5/16 inch nutdriver to remove the two screws inside the cabinet, near the top on either side that hold the front of the cabinet on.
  7. Lift the front off the two screws down at the bottom and swing the front around to the right without disconnecting any wires and lean it up against the side of the cabinet.
  8. Grip the drum with one hand at the rear and the other hand at the front. Be careful not to cut yourself on the razor sharp edges on the porcelain coated drum. Pull the drum forward to clear the rear bearings and then lift it up and out. Leave the belt on it and set it aside.
  9. (Figure 1) Now you have a good view of the heater shroud and coils. It will be easy to locate the breaks in the coils.
  10. Remove the broken coils. This task is made easier by cutting up the old coils into several pieces and carefully pulling them through the standoff insulators. Be gentle with the insulators as they are fragile.
  11. If these were original coils, the ends of the coils will be welded to the terminal bolts. Cut the wires off and remove the old terminal bolts by loosening the outer nut and disassembling the insulators. If the old terminals have the wires sandwiched between two nuts, loosen the nut on the end of the terminal. Again, be careful not to put too much torque on the nuts or you will break the insulators. Remove the remaining old wires.
  12. Prepare the coils for restringing by stretching them to specific lengths. Stretch the inside coil to 42 1/2 inches and the outer coil to 49 1/2 inches. These lengths are for a relaxed coil. It is better to have the coils too short than too long. If you stretch them too far, the coils will sag down and touch the metal heater shroud and burn up.
  13. Install the new terminal bolts through the insulators. Be careful not to break an insulator. You can't safely install the terminals with broken insulators and another trip down to the parts store to get new ones will slow down your repair a bunch.
  14. (Figure 2) Start threading the new coils through the insulators on the side opposite the terminals and work in both directions toward the terminals.
  15. (Figure 3) Note that both coils are connected to the top terminal and the other two ends are connected to the remaining two terminals.
  16. Use a needle nose pliers to wind the wires around the terminals between two washers and nuts.
  17. Slide the drum into its rear bearing
  18. Replace the three washers and the e-clip on the drum shaft in back of the dryer. Replace the bearing cover plate.
  19. Loop the belt behind the idler pulley, pull it back and then loop the belt around the motor pulley.
  20. Replace the rear panel and the dryer vent.
  21. Swing the front panel around and position it on the two lower screws. Use a 5/16 inch nut driver to replace the two sheet metal screws at the top.
  22. Lower the top and secure it with the 4 Torx screws.
  23. Plug in the power cord and check for proper operation.
Aug 03, 2011 | Indesit Microwave Ovens
The dryer is heating but the drum has stopped revolving what could the problem be and is it simple to fix.
Your dryer may have broken its belt, or the motor may have died.
A broken belt is "easy" to fix (if you've done a few), and not too expensive (if you do it yourself).
Replacing a motor is a little more involved (the drum has to be removed), and very expensive when
doing it yourself, and if you're not going to replace the motor yourself, it may be more cost-effective to replace the appliance rather than pay a technician to replace the motor.
A major appliance (dryer/washer) should last 10-11 years.
May 13, 2011 | Microwave Ovens
Where can I obtain a TECNIC model No. TKWF CP05 Water Filter Cartridge - as I have looked on this web site before and found the same questtion under the headings Home - Microwaves, but with no answer I...
Hi Graham
Having same problem - Tecnik phone number just rings and rings, their parts website is down and I just know they will charge a fortune anyway - anyone know of a cheaper alternative as all the filter suppliers I have tried don't stock anything that will fit? It has a 45mm push fit top and is total 253mm long - carbon filled plastic cylinder. Anyway if it ever gets back up try Tecnik:
0161 786 4921. website: http://www.tecnik.net/
Paul
Feb 25, 2011 | Microwave Ovens
Where can I find a step-by-step procedure fo replacing a belt on our dryer?
The instructions on replacing the belt on your dryer may vary depending on your dryer. However the principle on most dryers will be the same. A good video that will give you an insight and use is on the link below:
http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Hope this helps
Dec 30, 2010 | Microwave Ovens
I need to replace the existing 3-phase (with 4 prongs) lead on my (old) defy 621s stove with a single-phase lead (with 3 prongs) as my flat is not able to support 3 phase power. Can anybody tell me how...
This is for a dryer but the range is the same...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 30, 2010 | Microwave Ovens
Oster: Small hole in Mica Shield - Can't find replacement part
Dear Sir, Dear Sir, We manufacture and supply transparent mica shields(strips & discs) in all sizes/thickness. Please enlist our name in your vendors list and mail us your regular inquiries with sizes/thickness and quantity required. On receipt, we shall quote our best prices. Thanking you, R. Lall Hindusthan Mica Mart, Main Road, Giridih - 815301, India. lallgrd@gmail.com
Feb 01, 2010 | Sanyo EM-S5002W Microwave Oven
Microwave oven replacement Model#MWF307Z-3 Allegro series
You can look for parts here on FixYa,
good luck hunting, I have the same prob, with my Sharp convection M/ wave. I have been looking for 3 yrs. now and it only a 1982. Good luck DFD
Apr 15, 2009 | Microwave Ovens
What is the service shop telephone number for national make microwaqve ovens in Chennai, India
From this page:
Store Name Address Contact
TAMIL NADU
A.C.M ELECTRONICS 6/1 , SHOP NO : 1 , ANANDA GARDERN , BYEPASS RD , GANGAI NAGAR , VELACHERRY , CHENNAI - 42.
600042
City: CHENNAI
EXCEL ELECTRONIC INDUSTRIES 11-A , BIG STREET , KILPAUK GARDERN , CHENNAI - 600 010.
600010
City: CHENNAI
J.N & CO. 12 , BASEMENT , SAPTAGIRI COMPLEX , TTK ROAD , ALWARPET , CHENNAI - 18.
600006
City: CHENNAI Tel: 28265499 , 28271179
J.N & CO. A-7 , BASEMENT PARSN COMMERCIAL COMPLEX , 601 , MOUNT RD CHENNAI - 6.
600018
City: CHENNAI Tel: 24998199 , 24998399
M.S & CO 12 -B/17 , ELLAIMUTHU AMMAN KOIL STREET , VADAPALANI , CHENNAI - 26
600026
City: CHENNAI
R.N. ELECTRONICS 101 , A BLOCK , 3RD AVENUE , ANNA NAGAR , CHENNAI - 102.
600102
City: CHENNAI Tel: 42103987 , 26203569
RATHNA STORES 15 , RANGANATHAN STREET T- NAGAR CHENNAI -17
600017
City: CHENNAI Tel: 24342299 , 24311212 , 24311515
RATHNA STORES ( FIRM ) 43 , PONDY BAZZAR , T- NAGAR , CHENNAI -17
600017
City: CHENNAI
RATHNA STORES FIRM 199 , PURASAIWAKKAM MAIN ROAD CHENNAI- 600003
600003
City: CHENNAI
S.S ANNAMALAI SERVICE CENTER 123 , L. B. ROAD , THIRUVANMAYUR CHENNAI 41
600041
City: CHENNAI Tel: 24430257 24425059
SAMATH'S 95 , MOUNT ROAD , CHENNAI- 2
600002
City: CHENNAI
SAMRAT ENTERPRISES (P) LTD. 54 , LAKSHMI TAKIES ROAD , SHENOY NAGAR CHENNAI - 30
600010
City: CHENNAI
SANTHOSH SUPER STORES C-33 , 2ND AVENUE ANNA NAGAR CHENNAI 40
600040
City: CHENNAI
SHREE RAJ ELECTRONICS 3-A , ADAYAR BRIDGE ROAD , ADAYAR , CHENNAI - 20.
600020
City: CHENNAI Tel: 24917939 , 42054293
SRI LAKSHMI ENTER PRISES 9 , WAHAB COMPLEX CAMP ROAD , SELAIYUR CHENNAI 73
600073
City: CHENNAI
VICTORY ENTERPRISES 1 , EAST ROAD , WEST C.I.T NAGAR , NANDANAM , CHENNAI -35
600035
City: CHENNAI
VIVEKS LTD. 144 , ROYAPETTAH HIGH ROAD , MYLAPORE , CHENNAI - 4.
600007
City: CHENNAI
VIVEKS LTD. 167 , NORTH USMAN ROAD , T. NAGAR CHENNAI 17
600004
City: CHENNAI
VIVEKS LTD. 205 , PURASAIWAKKAM HIGH ROAD , CHENNAI 7
600007
City: CHENNAI
Jan 26, 2009 | Microwave Ovens
Microwave Ovens Logo
272 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
