Question about Bosch Water Heaters
The hotwater is still working but the lcd display has gone blank and the heating isn't coming on at all. Does anyone know what i could be and how to sort it? Please and thank you.
Open following link for Bosch tankless troubleshooting resources including parts, Bosch contact information, typical manuals, error codes, tech support, fuel-saver calculator, water heater forum, fixya links, disclaimers, and for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 29, 2011
Tip
Rest Electric Hot Water Tank Thermostat
I understand that you need to reset your hot water tank thermostat. Here are some instructions for you to follow with visual aids on what you are looking for and what you need to rest.
First you must locate the thermostat in order to rest it. There are usually two service panels on a hot water tank. The service panels look similar to the ones in the picture below.
justinbur167.jpg Once you locate the service panel(s) you will need to remove the top on and locate the thermostat the reset should be in the top one. You will be looking for the button that is located in the middle of the thermostat. This button will need to be pushed down firmly. The rest button is often red however; it comes in many different colors, shapes and sizes.
If the thermostat rest automatically pops back up then you will need to replace the thermostat. If you do not hear the heating elements heating up like in your coffee maker her the noise of the elements heating. You may have a bad element or thermostat of even both may be bad. The cost of rebuilding a hot water tank is cheap compared to replacing so I would suggest rebuilding. This is a pretty easy task that you can also receive help from FixYa for.
Hot Water Image: visualdictionaryonline.com: Copyright QA International 2011
http://www.bing.com/images/search?q=electric+hotwater+tank+&view=detail&id=947D2952ACE0C75D1DCEDB6216D99F764F1F2DB1&first=31&FORM=IDFRIR&qpvt=electric+hotwater+tank+
on Apr 09, 2011 | Water Heaters
Why no power to pump?
[PDF]residential hybrid electric heat pump water - AO Smith Water ...
www.hotwater.com/.../hybrid-electric-heat-pump-service-handbook-(32...
... MAINTENANCE -. OPERATION & SERVICE - TROUBLESHOOTING ..... Tools for servicing residential electric heat pump water heater models: • Container (to ...
How to troubleshoot electric water heater - Water Heater Timer
waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-...
How to troubleshoot electric water heater. ... 2) Heat pump electric water heater has fan and compressor and will make sound when operating Read 3) Clean ...
Jan 01, 2016 | Water Heaters
My gas hotwater syst not igniting.switch has power in and out,red light not working.no power in heater box.
You have to hold the button down in the pilot position to allow gas to go to the pilot while you click the igniter. Hold the button down for a minute or two to allow the thermocouple to heat up, then turn the knob on the gas valve to the normal position. It should work providing that the pilot is capable of remaining lit. If not, then it could have a defective thermocouple or gas valve (aquastat).
Apr 09, 2015 | Water Heaters
I have a tf325 bosch hotwater heater , problem is the flame will not stop when hotwater is turned off ?? Why and how to fix
After hot water has been drawn, the refill contents have to be heated to a set temperature in anticipation of the next demand. Otherwise, there would be a rush of cold or lukewarm water instead of hot.
Jan 27, 2015 | Bosch Water Heaters
On A.O. Smith water heater model BTH 199 100 where is the heat sensor rod located ?
Parts list:
http://www.hotwater.com/lit/partslists/197728-004.pdf
Flame rod, flame sensor sits next to igniter inside combustion chamber. This can be cleaned with sandpaper. Do not touch with fingers. Purpose of flame rod is to detect whether ignition has caused actual, sustainable fire inside the combustion chamber.
If sensor is bad, or no ignition is detected after 2-3 attempts, then 'no ignition' error is given.
Bad gas control valve, bad-or-dirty flame rod-sensor, low gas pressure, misaligned rod, dirty combustion parts, etc
Service handbook:
http://www.hotwater.com/lit/training/316586.pdf
High gas pressure spikes can daMAGE gas control valve p7
Product manual:
http://www.hotwater.com/lit/im/com_gas/197727.pdf
Word-search for 'failure'
Low gas pressure. p14 and p54
1-3 trials before declaring 'ignition failure. p48
bad flame sensor (clean with sandpaper) #10 p58
unit must be grounded (check outlet with circuit analyzer) #12 p58
Sequence flow chart p59
Rough starts = ignition failure p60
Troubleshoot chart - ignition failure p62
Mar 12, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
I have an instant hotwater system with the futher most bathroom about 45' away. I am looking at adding a recirculating pump on a timer at the furthermost bathroom to get hotwater quickly in the...
Maybe I am not understanding your problem exactly, but if you have the instant hotwater system installed it should be measuring the temperature of the water in the hot water line and if it drops below the set level it should open the hot water side until the temperature is reached. If it was installed correctly it puts the hot water back into the cold water line so it isn't wasted.
Sep 18, 2011 | Grundfos RCP-96 Recirculation Pump for...
I have hotwater in the tank but none at the faucets.
By-pass may be faulty. Are you getting good pressure on hot side, even though not hot?
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
Water leaking
it sounds like the gland on the valve is leaking unusual in a valve so young but it does happen. is the valve electrical operated or water pressure. you should be able to get a complete diaphram kit with all seals etc .
Nov 16, 2008 | Bosch 1600P-NG Natural Gas AquaStar...
Water Heaters Logo
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
