Question about Fuji FinePix S7000 Digital Camera
Has a message Zoom error and there is a grating noise when the camera is turned on to take photos. The lenz will not extend
  • 2,517 Answers
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Posted on Mar 15, 2011
Digital zoom error on an A600, lenz will not retract either
Have you tried spraying a can of compressed air into the lens assembly? All it takes is small piece of debris like a grain of sand to jam up the assembly.
Hope this helps
Jul 07, 2008 | Fuji FinePix A600 Digital Camera
The zoom browser does not recognise the camera is connected to PC
Windows updates change the registry. Sometimes this means our connected equipment no longer works. Now it is time for you to start using a separate card reader.
May 17, 2010 | Canon IXUS 80 IS Digital Camera
My sony camera gives this message and lenz will not close.
    This message appears when the lens assembly start malffunctioning. Therefore, You have to replace the Lens Block Assy. For this plz contact any nearest Sony Service Centre nearby to u.
Thanks for using fixya!
Take care.
Mar 11, 2009 | Sony Cyber-Shot DSC-S90 Digital Camera
'zoom error' on olympus sp-560 uz
I had this problem and managed to fix it. The camera was dropped on a stone floor and the zoom error was present every time it was turned on. A ring or other piece of the lens was bent or damaged, in my non professional opinion. A profesional repair is my advice. However you may try my fix at YOUR OWN RISK.
Switch camera on, when zoom extends, but before it closes down due to zoom error, gently but firmly push lens back in. Drop batteries for camera to reset itself. Repeat, if necessary.
My camera now operates fully and when the lens extends it now no longer makes the slight grinding noise.
Good luck and remember at your own risk.
Jul 30, 2008 | Cameras
Lens error
First check the battery for full charge.
This may be a damaged lens system.
Lens error is usually E18 or text "lens error" or other error message.
What you both can try is something I have tried and fixed some cameras.
As the camera starts, gently push in on the lens or pull..that may be able to be determined by the way the lens acts. You have to study carefully the lens as it is extending to see what happens.
If any noise is present as it is extending, then you may have internal parts which are broken in the lens. Sell it for parts on a site such as Ebay. List it as is, parts, or repair.
take care,
Jun 23, 2008 | Nikon COOLPIX L3 Digital Camera
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 07, 2007 | Olympus SP-350 Digital Camera
Error message E25
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Oct 09, 2006 | Canon PowerShot A100 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
19 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
