Question about Cisco 2514 Refurbished Router (CSCO2514)
Cisco 2514 does not switch on straight away. It powers on about 1min after switch depressed. it also loses the correct date and time if switched off.
    Problem Solver:
  • 11 Answers
If you issue the command show version
At the bottom written in bold you should the config register settings these nee to be as shown at the bottom of this page
R1#show version
Cisco Internetwork Operating System Software
IOS (tm) 2500 Software (C2500-JS-L), Version 12.1(3), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Thu 06-Jul-00 10:02 by cmong
Image text-base: 0x0306F914, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFT
WARE (fc1)
R1 uptime is 1 day, 5 hours, 39 minutes
System returned to ROM by power-on
System image file is "flash:c2500-js-l.121-3"
cisco 2500 (68030) processor (revision N) with 14336K/2048K bytes of memory.
Processor board ID 11844920, with hardware revision 00000001
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Configuration register is 0x2102
if yours differs the use the these commands to correct it
R1>en
R1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)#config 0x2102
R1(config)#^Z
R1#
Hope this helps
Posted on Jun 01, 2011
The power devices that Cisco Catalyst 2960 Series Support?
The Cisco Catalyst 2960-48PST-L can support 48 PoE ports with total PoE power output capacity at 370W. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE devices at 15.4W for maximum powered-device support.
The Cisco Catalyst 2960-24LT-L can support eight PoE devices at 15.4W
Cisco Catalyst 2960 Switches for the details
Aug 15, 2014 | Computers & Internet
Cisco Catalyst 2960-S VS 2960-X Series Switches?
2960-X is manual configurable and 2960-S is smart dont need to configure.
Apr 10, 2014 | Computers & Internet
Default password for a Cisco SG200-26? cisco, cisco do not work .. ??
I had the same issue after what I thought was a succesful reset. It turns out I hadn't reset the switch completely. There is a reset pin hole next to the power switch. Hold it in with a paper clip for at least 30 seconds. ( I was holding in the power button for 30 seconds.)Then you can use the cisco admin and cisco for password defaults. Hope this helps someone in the future since I spent WAY TOO MUCH TIME on it :)
Oct 27, 2012 | Cisco SG200-26 24 10/100/1000 Ports,...
How do I connect cable modem to cisco 3560 switch and configure it?
The cable modem will need to go through a router because it needs a NAT and PAT translation table, connecting the cable modem direct would lose the ability to get to the internet.
Jun 05, 2012 | Cisco Catalyst Compact 3560-C PD PSE -...
I have an Innovera IVR 16015 calculator and need instructions on how to change date and time
I have an IVR-16015 calculator on my office desk. I too was looking for instructions on how to set the time and date and found this site. The previous information is wrong. I just discovered how to set it... The switch needs to be set to "ON", then press and release the blue "TIME" button to toggle between displaying the TIME or DATE. Depress and hold the "SET (=)" button for about 3-seconds to enter edit mode then use number keys to modify the displayed value. Depress the "SET (=)" button to save input and exit the edit mode. Pretty simple when you have the correct instructions, huh? By: The Fox
Mar 21, 2011 | Office Equipment & Supplies
We are experiencing some NW problems with our Cisco 7940 hardphones. We have several installed and for some time now it seems that these hardphones just lose their default gateway configuration and stop...
I would check the firmware on the phones. Also, check that your switches are properly configured. Duplex settings do matter. If your using cisco switches; do a "show interface" and check for CRC errors etc.
Jun 25, 2010 | Cisco 7940 IP Phone
Can not get my plantronics calisto phone to par with the headset or the base
We have two of the Calistro Pros and they will lose contact all the time for no apparent reason. Most of the time when I walk to far away from the handset they will beep and there will be the "OUT OF RANGE" will display. I have found that while sitting next to the phone press the ear piece switch straight in. You will hear a series of tones either getting louder or going from high to low. Wait a few seconds after pressing the ear piece switch and then look at the hand set. the No Headset circle should dissaper. If not depress the earpiece switch and listing for the tones again. Wait again and they will find each other. If this does not help you then I think you have a phone issue. I use my for 8 hours a day and have to do this several times a day. I hope this helps.
Apr 09, 2009 | Plantronics Calisto Pro Series Cordless...
Cisco 2960 power supply
The Cisco 2960 has a life time warranty. Contact the seller and they should be able to get the switch exchanged at no cost.
Jul 31, 2008 | Cisco Rf Catalyst 2960 24-PORT 10/10
No power
Here are a couple of ideas...
Check out ebay item #140197449460
- or-
http://www.cablesandkits.com/cisco-power-supplies-c-63.html
Jan 18, 2008 | Cisco Catalyst 3560-24PS Switch
Computers & Internet Logo
476 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
