Question about McCulloch 4 Ton Electric Log Splitter # FB4052
5 ton electric woodsplittr wont return to start
    Problem Solver:
  • 13 Answers
Look for a limit switch that might have debri in it not allowing it to read properly.
Posted on Mar 16, 2011
Timber tuff 5 ton eletric log splitter will not move
check/replace the start/run capacitor/s
check that the hydraulic pump is not seized
Oct 26, 2015 | Timber Tuff 5-Ton Electric Log Splitter
My maytag neptune dryer control panel wont light up wont start
You have a bad control board that will need to be replaced. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 03, 2013 | Maytag Neptune MDE5500AY Electric Dryer
What are twinned units?
Twin units can be two airconditioner condensers and/or two furnaces. Most manufacturers make a twinning kit that will wire two units together to operate simultaneously by one thermostat. At times, one may operate as a first stage of heating (cooling) and then the other unit can operate as second stage. Twinning unit are beneficial in commercial buildings where the load conditions vary constantly. For instance, if you twin two 4 ton units together. On a nice cool day, you may only need 4 tons of air conditioning. So, the thermostat will only turn on one unit. On a hotter day, you may need 8 tons of air, so the thermostat will turn on both units. In case you are thinking about doing this, the biggest mistake in twinning units together is using a common return air for the furnaces. Make sure you separate the return air cavities and ductwork for both of your furnaces If you don't have separate returns, you have the possibility of one of the blowers starting backwards. (talking form experience LOL)
Aug 13, 2011 | Heating & Cooling
I have an 02 gsxr1000.Irode it on monday it ran a little rough. , parked it then went to ride it tuesday, it wouldnt start. upon turning the key the fuel pump relay clicked on , the tach pegged and...
Yes, you are right. It is the fuel pump. Fix or Replace and your good to go.
A customer of mine wanted me to change his fuel pump, because his didn't work.
When i was taking it off the bike i noticed a broke wire - fixed the broke wire and the fuel pump worked - check the wires to it too. It happens, saved him alot of money.
Happy Holidays
Dec 03, 2010 | 2003 Suzuki GSX-R 1000
Bought from insurance company was flooded said there was no mechancial problems now the car wont start, charged the battery and there are tons error lights and check engine
definitely electrical problem. Possibly the ECU (engine control module) You could try to take the negative lead off the battery, turn the lights on (to try to drain the power from the car's computer), reattach the battery lead (to reset the on board computers) to see if it starts.
Jul 21, 2010 | 2002 Chevrolet Cavalier Coupe
I own a 1978 motor home with a qne ton van frame\r...
Over an extended period of time gas will evaporate in a carburator. It's possible that presure is leaking off in your fuel pump as well. A weak pump will have trouble maintaining pressure over a period of time and will have trouble building pressure back up. Starting the engine on a regular basis and letting it run for a few minutes will cure the problem and help keep the engine seals from drying out and leaking. Converting to an electric fuel pump will also make it easier to start after sitting for a period of time.
Any generic LOW PRESSURE electric pump will work. It only needs to put out between 7 and 9 or 10 pounds pressure. Unhook the fuel lines from your mechanical pump and hook to the electric. The li ne from the tank goes on the inlet end. The electric pump usually ground through the case so it needs contact with bare metal or a wire running from the case to bare metal. Run the power wire to a powered wire in the engine compartment that powers on and off with the key or to an accessory fuse in the fuse box. It should run through a 20A fuse.
Hope this helps.
May 20, 2010 | 1983 Chevrolet C3500
1989 Chevy 1 ton wont start
It is likely the electronic ignition control module. When they go, they just go bad and usually when you are driving.
If it was a smaller vehicle it could also be a timing belt but your's has a heavy duty valve train so no worries there.
Mar 17, 2010 | 1989 Chevrolet C/K 3500
Hi, we have a problem with our Weatherking heating unit/ air conditioner. We had it installed 07/20/06. It really never has worked properly. For the last 2 summers in run's constantly. Which of course...
Lets look at the whole problem. Did you have a new unit inside. Is the charge correct for unit. 1 lb of refrigerant makes difference. Four tons should be big enough if you have proper insulation. I have three tons in a 2100 square foot house. Its plenty big enough. You may have to small a return air. To small a return can cut a four ton unit to 2.5 ton unit very easily. 1.5 square foot pf free grille area per ton. Rusty
Jun 08, 2009 | Weather King 12AJA4801AH Air Conditioner
McCulloch 4 Ton Electric Log Splitter # FB4052 Logo
215 people viewed this question
Top McCulloch Tools & Hardware - Others Experts
ArcFlash
Level 1 Expert
Tom Chichester
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a McCulloch Tool and Hardware - Other Expert? Answer questions, earn points and help others
