Question about Fedders 9,000 BTU Electronic Portable Air Conditioner
Unit triping braker when compressor turns on
The breaker is underrated the power that it takes to start the compressor is really big but only for a few seconds. That is called the inrush and the breaker should be rated for HVAC wich allows for this.
Posted on Mar 15, 2011
Quiet master SL36L30A-C outer fan broke loose and then unit triped a braker. With new blade should unit be ok
Not sure of the damage that the spinning blade did, but the breaker did its job. I would ohm it out for shorts before powering it on though. How long was it tipped over. was it righted immediately. This is very important, because you don't want liquid refrigerant in your compressor, or it's done when started. If you didn't right it immediately, then use a hair dryer or heat gun to boil off any liquid refrigerant that may have entered the compressor before you power it back on.
Feb 29, 2012 | Friedrich M18CF Split System Air...
Keeps triping braker
ARE YOU TALKING ABOUT TRIPING A FUSE ?IF SO ,YOU HAVE SHORT CIRCUIT.
May 26, 2011 | Chevrolet Tahoe Cars & Trucks
I have a Kenmore model 20802990 washer, it will run for a short while and then stop working, it is almost as if the circuit breaker trips because when I turn the circuit breaker of then back on and switch...
well you right in saying "its triping the braker off" thats what it is doing,,
there is a problem with the washer motor,,its pulling far to many amps so its a fulty motor,,,and it will just keep triping the trip out,,,
its a good job you have trips,,the motor could have gone up in smoke
Jul 15, 2010 | Kenmore 24032\24036 Top Load Washer
Hi, i have a craftsman 5 hs compressor and it just started tripping breaker every time i turn switch on. it tries to run several seconds at partial power before actually triping breaker. i have checked...
if the compressor turns over freely then you have a motor fault its likley to be a short in the windings causing it to loos power and therefore pull more amps this in turn pops your brakers as it is a 5hp 110 volt motor will pull nearly 45 amps witch if nearly half the power that my house runs on (but at 230 volts i have twice the pushing power)
Jan 17, 2010 | Air Tools & Compressors
My Whirlpool dishwasher ADP951 does not start at ll. I think I turned off the machine last time before it completed its cycle. I found there was water left at the bottom unlike after a usual run. I...
If your dishwasher is on a wall switch, someone may have shut it off, Your dishwasher could be pluged into a Daisy chaned GFI, check all your GFI in the kitchen and make sure none are triped. The home Fuse Box, make sure the braker is not triped.
After all that has passed, there is a power conection box under the machine. Make sure the power is off from the breaker box or the machine is unpluged before inspecting under the machine or trying to repair this machine.
Jan 10, 2010 | Dishwashers
Keeps on triping braker
Unit should be tested, You have a "ground fault" condition.
May 26, 2009 | Whirlwind FH-778 Air Conditioner
Circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
May 01, 2009 | Dometic RM2852 Refrigerator
My ULine icemaker just started triping the GFCI plug.
Ground fault should not be used when you have a compressor plugged to it. The start amps can trip a ground fault. You can try to plug the unit on a regular outlet and if it doesnt trip the breaker then unit should be good. You can try to replace the ground fault if you need it (but make sure you have a higher amperage on the new one.)
Dec 23, 2008 | U-Line Icemaker
Fedders 9,000 BTU Electronic Portable Air Conditioner Logo
66 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
