Question about Video Game Consoles & Games
How do i reset all my settings for my PS3? I've been using an HD cable for my video/audio output and when i switch to the regular cables the screen just stays blank and I can't get to the menu. How do i fix this??
  • 659 Answers
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Posted on Aug 01, 2008
Hdmi ports not working
reset your playstation 3 video setting
Reset Video Output
If you are changing cables or cannot see an image on the screen, you may need to reset the video output to default settings. To reset the video output:
  1. While the PS3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PS3 beeps a second time (approximately 5 seconds), then release it.
  2. The PS3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 21, 2013 | Sharp AQUOS LC-40LE830U 40" LCD LED HDTV
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
The new AV cable will not fit into the slot in the ps3. Used a regular composite cable prior to trying the new HD cable.
connect the hdmi as normal , then use the composite cable to the headset and in audio output settings enable audio multi out , that will output audio to both the hdmi and composite audio jacks .
click here to download repair guide... u can do this by yourself....
Dec 22, 2010 | Sony Playstation 3 (PS3) Console
PS3 HDMI - Sony Bravi KDL-40V2000 Problem
  • Have your ps32_bing.gif in standby mode (red light).
  • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 08, 2010 | Sony Playstation 3 (PS3) Console
Nothing shows on screen when inserting game , i hear the disc is turning but nothing shows on screen
Make sure you have the cables hooked up properly, regardless of whether your using an HDMI cable or regular A/V cables.
Best thing to do in a case like this is to do a factory reset on your PS3. Be sure that the A/V cables are being used originally and are hooked up properly.
Here is how to do the factory reset on a PS3:
Try that, if you still don't get video and you know the cables and the TV are set to the right output then its an issue with the main board not having any output.
Apr 22, 2010 | Sony Playstation 3 (PS3) Console
My ps3 does not work after i used the hdmi cable on my friends new t.v. when i came back to my house i put in back on my older tv to use the regular cable and the screen is just black. what could be wrong...
This is because the PS3 is trying to outpur in Digital... you have to reset the video output to work on your analog tv again... try this.
turn the unit off... if it is on hold the power button on the unit.
while the unit is off hold the power button untill it beeps, then go into the setup and reset the proper settings for your tv.
Jan 28, 2010 | Sony Playstation 3 (PS3) Console
My ps3 has no picture or sound...
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
Jan 22, 2009 | Sony Playstation 3 (PS3) Console
Ps3 start up promlem
so if you have ever had your ps3 connected to HDMI (HD cable) before, and your forgot to change it back to the normal cords that came with the game (yellow, white, and red) then you will have to connect it back up to the HDMI and go to the Display Settings and change your video output to the one that came with the ps3 (which looks like just one yellow in the settings.) then after you do that then the screen might go black if your HDMI and regular cable are on a deffirent channels, so you turn to the channel that the yellow white and red cable needs to be to, then it will show the screen and ask you if you want to leave it at this setting with this video output/cable then you say yes then your good to go.
Oct 09, 2008 | Sony Playstation 3 (PS3) Console
Screen blank no sound on ps3
Put the PS3 in standby mode (red light) then hold down the power button on the front for about 10 seconds until you hear a beep. That will reset the output to factory settings.
This is usually caused by using an HDMI cable, and then switching to the regular Playstation cable.
Jun 11, 2008 | Video Game Consoles & Games
Video Game Consoles & Games Logo
42 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
