Describe your sherwood receiver amplifier Problem Thermal cut out, amp stay's on for a few seconds
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 15, 2011
Phono input only plays one speaker and receiver shuts down after playing record for a few minutes
are you using a phonograph with a built-in preamp? If so, then you need to hook it up to a different input. Phono input is only for non-amplifier phonographs, otherwise you will over-drive the amp.
Oct 10, 2015 | Sherwood RX-4109 Stereo Receiver Black
I have Sherwood rd-6106 amplifier and when i turn him on it goes back to standby after few seconds. can anyone help?
bad fuse, something is sending it to sand by to keep from ruining the rest of it, have it looked at by a pro technician
Feb 02, 2015 | Sherwood Audio Players & Recorders
My audio/video receiver which was playing well but all of a sudden turned off as I was attaching a speaker wire to it. Now it will only stay on for a few seconds before 'clicking' off. Can you...
I guess you missed the part where it says to power everything off while making connections.
It sounds like you shorted the amplifier. Try it one moretime without any speaker cables attached. Then take it in to a Tech.
Jun 23, 2011 | Sherwood Audio Players & Recorders
My Clarion APX480M marine amp cuts out at random
try to unplug each speaker one by one while playing it. There can be a defective speaker that grounds out at the speaker terminal or internally causing the amp to go into protection causing all the speakers to go out.
Jun 05, 2010 | Clarion APX480M Car Audio Amplifier
Denon 528 amplifier cuts out after a few minutes
disconnect the speakers and see if amp will stay on. if this the case maybe suspect one of the o/p amps
Feb 08, 2010 | Denon AVR-587
Power cuts off after 2 seconds after stereo start button is pressed
Disconnect your speaker wire's from your receiver, and then turn the receiver on.
If your receiver cuts off with the speakers disconnected, there is something wrong with your receiver, and take your Sherwood receiver to a qualified reputable technician.
If your receiver stays on with the speakers disconnected, their is a short circuit either in your speakers wires, or in your speakers. Make sure your speaker wires are pushed all the way in the speaker terminals in the back of the receiver, and do not leave no naked speaker wires exposed. If you have too long of bare speaker wires exposed at the receiver's speaker terminal, or at the speaker's terminals, they could touch each other, and cause the receiver to cut off. If the speaker wires are OK, then you may have a short circuit in your speakers.
Nov 12, 2009 | Sherwood RX-4105 Receiver
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Sonamp 260 cuts out
Normally this denotes a protect condition. Remove the speaker wires from the back of the amp and see if the green light stays on. If this fixes the problem, then there is a short circuit in your wires, speaker level volume control or speakers. The amp sees the short and goes into protect. After a couple seconds it closes the connection again and if the short is still present it goes back into protect.
Aug 03, 2008 | Sonance Sonamp 260 MKII 2-Channel...
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
Sherwood Amplfier
Sounds like you like your music like me... LOUD. If you've done this a number of times, there are a few things that can happen:
1. You've blown the speakers... but you've said it operates for 2 seconds, then cuts out.
2. You've damaged the amplifier modules within the amp and they immediately overheat upon power-up. Does the music come back like 5 or 10 seconds after the unit cuts out?
3. Thermal switch has malfunctioned and just cuts off the power to the amplifier modules as soon as it sees any heat.
4. If you've gotten the amp really HOT during playing, it's possible that it's as simple as the amp modules are only intermittently connected (fatigued/stressed or cold solder joints) at the on the PCB. Just resolder the connections of the amp module to the PCB. I've seen that happen numerous times and that's where I'd place my money.
Jan 02, 2008 | Audio Players & Recorders
79 people viewed this question
 Grubhead
Grubhead
