Question about Car Audio & Video
When i try to turn the sensitivity up or down its like the amp will push full power then cut back power. if i wiggle the control its works right then the same thang.
    Sniper:
  • 50 Answers
Hello... sorry to hear you are having problems. It sounds as if you have dirty pots inside the amplifiers attenuator. They make electronic cleaners that you can spray into the opening to remove the dust and debris that will accumilate inside electrical components. You can purchase this cleaner at Radio Shack. They may have it at WalMart as well. Check in the computer area. The spray is kinda expensive. After spraying the level control, take and rotate it back and forth and spray it again. Repeat a couple of times. If it still does it after this process, then you will need to take it in to be serviced. Hope this helped! Good luck with your venture!
20 year car audio/video installer
Bay manager
Posted on Mar 15, 2011
Volume control ultra sensitive. A touch can cut off a channel or cause a 'fuzzy' sound. How can I fix it?
Your pot is dirty. Pull the plug on amp and take the volume control and go from full low to full high back and forth about a hundred times.
Plug unit back in and turn on - it should be working better now. If you have electronic cleaner you can also squirt some of that stuff into the pot.
Sep 09, 2015 | Audio Players & Recorders
Radio works but no sound
Don't laugh...but have you a) turned the volume right down. b) hit the 'mute' tab. c) tuned to a channel d) made sure antenna is up ? now it gets interesting e) checked the amp fuse inside the device f) checked the connectors from the speakers.......now the good bit.... wiggle the ignition key gently while engine running also gently pushing key in further.... it happened to my standard original 2001 lim ed still does, the wires cross inside . when engine on and radio going, it cuts out, sometimes just the display, sometimes whole thing blanks out.. comes back on when I tap key in. weird but true. sounds like amp fuse blown (right inside radio itself) Red
Apr 04, 2014 | 2002 Chrysler PT Cruiser
My 602 xls plays for 25 mins and then switches off. I switch it on after 5mins , It then works but switches off again
Got the same problem on my amp right now.
Trough the schematics i could see that transistors bc184l & bc214l could be the cause in my case. If i turn it on, it can be ok for hours. Untill i turn up the knob with a speaker connected, in 30 sec it shuts down. The PTC on the rectifier board gets hot and also R21&R23 a bit. I will try to change the 3 pnp/npn and also tip50G.
I'll tell you how it will be...
One Love
Cesare
Apr 20, 2013 | Crown XLS 602 2-Channel Amplifier
I have a Peavey Bandit 112 amp that takes between five and ten minutes to warm up. It use to come on right away. any suggestions?
Take it for repair immediately as there is something that is thermally sensitive and it may cause worse damage with continued use. The problem is LIKELY a broken solder joint. Depending on where it is, it could cause damage to the power amp portion. It OFTEN is at one of the leads to a volume control and those USUALLY don't cause damage, but one can't be sure till it is repaired. These broken joints oxidize and then eventually warm and punch through and the device starts working. You MIGHT want to try wiggling the controls to see if one brings the unit on immediately showing itself as the culprit.
Apr 02, 2011 | Peavey Bandit 112 Guitar Amplifier With...
2001 yamaha yzf 600r the key is turned to lock
you need to take the pressure off the steering, example, hold the steering just slightly off the full left or right position. Wiggle or move the handle bars slightly and try turning the key. Sometimes there may be too much pressure on the steering lock for it to move, Also some thing eles to try, try pushing down on the key as you turn it. Hope this helps.
Jun 01, 2010 | 2001 Yamaha YZF 600 R thunder cat
While cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
Jan 02, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a qsc collection of amps and they all seem to omit static
Go to Radio Shack, and ask for "Tuner Wash" it's dust buildup on the moving controls. Pull off the knobs, use the small spray tube (usually red) and spray a small amount directly on the control. Let it set for a couple min, then work the control up & down a few times, then turn the unit back on. You may have to do this a couple times to get rid of it all. If you have a fancy faceplate on the unit, if you can take it off, do so, the cleaner can leave marks on plastic or varnish and cut thru lettering. Just be careful. Hope this helps
Jun 22, 2009 | Audio Players & Recorders
I have a Hifonics XXV Colossous and 2 JL 500/1's. I want to know which I should use to push my 2 12" W7's to get my full money's worth and the best of the subs. Also if someone can describe how I should...
i highly recomend you use the hifonics colossous and wire the subs @ 2 ohms and you would be right about nominal power handling for the W7 which is rated @ 1000W, and your amp would push about 1100W to it. just be carefull when adjusting. and the best advice i can give you on the settings is as follows: Turn up the volume to the desired listening average level. (what you would normally have it on when driving) then adjust your amp by turning the different controls up, and then back down a 1/4 turn after distortion occurs. in your case with so much power dont turn them up all the way right away ease into it be gradual listen to the change in the sound.
Mar 04, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Nad C320 right channel stops working then comes back again
This sounds like the "pre-amp" section is cutting out or there is some interruption in the signal path. A few things to try:
1) With the unit off, try "working" the volume,balance and tone controls. This means, turn them up and down a number of times to clear any debris that may be in the controls themselves.
2) Work the input selector switch the same way if it is a rotary switch.
3) Try turning on/off the tape monitor switch a few times.
4) Keep track of whether this problem is sensitive to heat. Does teh channel shut down more quickly once the unit has been on for a while?
Lastly, if you can solder, look for any solder joint that appears grainy or has rings and resolder it.
Update this with your results and we'll continue on...
Thanks,
Dan
Jan 15, 2009 | NAD C320 2-Channel Amplifier
Amplifier power cutting out
not enough power to amp and or amps location is too hot might want to invest in a couple cooling fans from computer store and attach where needed
an amp should take up to 3/4 load but when not enough air to it to cool it off it will shut down
try this turn gain all the way down and slowly work up too desired amp volume setting
May 07, 2008 | Audio Players & Recorders
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
