Question about Home
I have 2 outside lights linked together the 1st one works the 2nd one does,nt
  • 827 Answers
How close are they are they on the same fixture, or are they a distance apart, also are they wired to the same power?
Posted on Nov 24, 2013
How do I hook up a trailer to my 2008 Acura MDX?
most vehicles have the plugins close to the hitch, if your vehicle doesn't have one outside, one it may be inside the tool compartment, in the back. the 1st link is an installation for a 2007 which should be the same. the 2nd link shows the wiring harness if you want to order one & install yourself.
http://www.youtube.com/watch?v=nsxIBx6LOA8
http://www.etrailer.com/t1-2008_Acura_MDX.htm
Sep 14, 2014 | Hoppy Hopkins& Plug-In Simple Multi-Tow...
Installed 2nd switch it does not work
If you are talking about A THREE WAY SWITCH, they can be a little confusing for a beginner.
here is a link to some drawings that might help.. IF YOU ARE NOT TALKING ABOUT A THREE WAY SWITCH, give me a little more information. 3 Way Switch Wiring Diagram
May 04, 2014 | Leviton 5603 Decora 3-Way Switch
Dishwasher lights flash half way through program
you will have to consult your owners manual
Jun 07, 2012 | Dishwashers
I have got one power cable going to a 2 gang switch and need to feed two seperate lights off it.
Hello.
All whites are marretted together,
  • white power - white 1st light - white 2nd light
Blacks are the return for each light, and are joined after passing through the switches,
  • black FROM 1st light - top of switch - bottom of same switch - black power AND other black from 2nd light (see next step)
  • (repeat of above) black From 2nd light - top of 2nd switch - bottom of 2nd switch - black power AND black from 1st light
NOTE: both switch blacks are marretted together to the black of power. Ground all 3 as normal to dblgang box. Total marrettes required is two (three if using one for grounds) Hope this helps. If so, please rate a four-thumbs up, Thank You.
Apr 02, 2011 | Home
96 chevy blazer 3rd gear and overdrive slipping
i got a 1996 chev. blazer s-s10 4.3 engine 4x4.problem i got is i got 1st 2nd & overdrive & reverse but no 3rd gear what should i do
Jun 30, 2009 | 1996 Chevrolet Blazer
Lights dim and radio and A/C turn off together for about 5 second
Your issues has more than one cause. The shifting into 2nd and 1st are separate to the radio & A/C. The blinker circuit is ALSO separate to the radio and A/C. The electrical system needs to be diagnosed, starting with the battery & charging system... Then look for any bad gound circuits/cables... starting with the battery, then chassis, then any individual power components (TCM, A/C, Lights, blinkers, A/C blower motor & controls, etc.)
Jun 03, 2009 | 2006 Hyundai Sonata
I have 2 3COM 3CRWE454G75 -> AP, it does work in AP repeater mode
find the ip address problem or the firewall of there or proxy servr is there and re-configure it then you get the it and check the region if not same that also creating problem sir,
Mar 04, 2009 | 3Com OfficeConnect (3CRWE454G75)...
I need a wiring diagram for a Intermatic T104 40-amp timer
http://www.intermatic.com/images/instruction_sheets/T104.pdf
http://www.intermatic.com/Default.asp?action=cat&cid=91
if the 1st link doesn't work, use the 2nd and look for ur timer model there for the diagram.
if u need more help than this just ask
Tip: i usually use a photo cell in combination with the timer. i set the time for winter hours and let the photo cell take care of the rest.
Jan 02, 2009 | Electronics - Others
1st and 2nd light Blinking forever!!!!!
http://www.amazon.com/RCA-DCM315R-30Mbps-Cable-Modem/dp/B00009UI2Z
read it!
Jun 06, 2008 | RCA DCM315R Modem
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
