Question about Car Audio & Video
REMOVING A BMW RADIO TRY TO FIT A PANASONIC CD WILL THE PLUGS FIT
  • 22,246 Answers
Be carefull here and make sure you buy the right adaptor bits as these cars use a speed control to increase volume and if you get it wired up wrong it will cause problems with all sorts of things from autobox gear changes to lights appearing on the dash .but if its an older model you may even find the plug fits into cable end for the new one as they are all universal ,but they will not fit directly into the new one i dont think
Posted on Mar 15, 2011
I wish to replace my original bmw e39 radio/casette with a genuine bmw radio/cd player-problem is there is only one multiple round pin socket that fed both units, with the new radio/ cd unit, a seperate...
best advice i can help you with is modernise and fit a aftermarket radio which has usb and sd card support then you will not need the additional CD player in the boot ,old hat now these things when you play a 1 gb sd card and have 30 cds on it .
Apr 30, 2011 | Car Audio & Video
Can I change the battery in my 2005 BMW Z4
Yes. But before removing battery terminal get a memory saver that either plugs in at the power source outlet or the type that plugs into the OBD ii communication port. This will leave voltage power for the computor and accessories that have memory. Like the radio and if the car has memory power seats. And if the factory stereo has a Anti-Theft feature it won't get triggered from a power loss.
Apr 04, 2010 | 2005 BMW Z4
When I remove the OE Radio head unit to fit a new JVC Radio CD the vehicle developes alarm/stating faults.
car is earthed thru the radio. when removing the earth connection of the radio clip it to a metal piece of framework thats obv earthed...
Feb 21, 2010 | JVC Car Audio & Video
I have a CD stuck in my BMW 6 CD changer A. The magazine comes out. Is there a reset button or anyway of removing this CD?
If it's like mine, you have to take the cover off and feed the disk back through the loading mechanism.
Oct 07, 2009 | 1999 BMW 318 ti
Radio and cd changer for bmw m3 e36 ea88906
If you go to www.crutchfield.com they will have a menu for all upgrades to your vehicles sound system including which head units (or stereos) will fit your Bimmer.
~Stillin~
May 21, 2009 | 1994 BMW 3 Series
How to connect a panasonic cx-dp880 cd changer to a cd receiver
My records do not indicate that they are compatible but are unclear, there may be some special connector used, none is listed however. Although if the cd changer is not a direct plug in, you can use an FM modulator. This device plugs in between (or wireless ones sit near) the antenna and radio transmiting a signal of it's own usually around 88.5 or so. Your cd changer or any other audio device plugs in to the modulator and it transmits the audio signal via an FM radio station. You then tune in your radio to the designated frequency and you're done. The only problem is weather or not your cd changer has a controller built in to facilitate this type of install.
-Dynami
Apr 06, 2009 | Panasonic CQ-RX400U Car CD/ MP3 Player
Wiring stereo 1995 BMW 318Ti
HI, you do not need a wiring diagram, do you have a stereo already installed, if it is factory it is probably a baupunkt or a pioneer, although no bmw came with a radio as standard years ago, they where all fitted at the dealers. check for your constant positive with your meter. then find the ignition positive, ie.only on with the ignition, the constant keeps all your programmed channels. earth noemally brown on a bmw. but live in you're house!! green with a yellow tracer or line in your house is earth. then the feed to the electric aerial if you have one, if not forget about it, i think it is grey? then you just need your speakers, they are normally on a totally different plug, if you have 2 plugs thet are din plugs, or deutsch industrie norm. or in english german standard normal. It is a set size or measuremeent, din radio will basically fit into that size of hole in a dashboard.the speakers are normally gery with a black tracer, white with a black racer etc. if you touch these and do not get a shock they are speaker wires, ...only joking, you cannot get a shock from any of them..It should be easy enough to swap over especcially if you are just upgrading to anothr radio. just undoo each speaker with the stereo on to see where thet are located in the car, you cannot do to much damage. if the wires are say grey and grey with a black tracer, if you wire them up black and then grey with black tracer the wrong way around , they will still work, its not like putting the positive to the earth etc, on the radio.I doubt if there is actually a wiring diagram for basic bmw models, except for the 7 series top of the line, in the 80's the radio case for it to fit into was not even in the top of the range 5 series, we had to fit them in, the latest 3 series which had it in the dash came in from germany with a big plastic plate where the radio should be, datsun started fitting radios,as standard roll on nissan....
Dec 09, 2008 | 1996 BMW 318
Radio conector problem
Try halfords they do a lot of car audio conectors.You give them the name of of the product your fitting and the car you want to fit it in.usually a universal plug is offered.plug it in your radio then into your loom and away you go.No additional wiring no mess.Usually costa around £7.Hope this helps.
Jun 27, 2008 | 1992 Toyota Camry V6
BMW 328i - 1997 model RADIO - fit shuttle?
Hi Guys
Have found a company to fix my problem.
Thanks
Flippers
Jun 11, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
