Question about U.S. Robotics USRobotics Wireless MAXg Range Extender USR5441 wireless network extender (S4466719)
Will, if the IP is dynamic the gateway will not be defined by the PC it will be as follows; 192.168.254.2, sub 255.255.255.0 gateway 192.168.254.254 while this is the main modem IP actually. The extender IP is 192.168.254.29. When I set the gateway as 192.168.254.29 test is ok up to gateway but the ping to gateway is failed.
  • 1,591 Answers
Your gateway is whatever the router's ip address is (ie, 192.168.254.1)
Posted on Mar 15, 2011
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Assign Internet access to the second IP Gateway
Your quest is very confuse.If you have a router that one only have 1 IP gateway and if DHCP is enable, then the router assign all IP,s to all PC,s, DHCP is not enable you nedd to assign IP,s for the PC,s.
So 192.168.0.1 is the default gateway and from that IP with DHCP enable all IP,s will have the same first 7 digits of the gateway and the last will be in the range of the gateway,So the ip of aother pc,s will be like 192.168.0.2,192.168.0.3 and so on.
Jul 04, 2013 | Zhone 6212-I3-200 Router
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
My computer is saying connected to router but no internet and my cable light on the router is not lit. (yes the cable is active on my tv) Any suggestions on the problem and a solution
if its the first time you connected the router ...you have to make the wlan connection ..and clone the Mac address on the router to fit the old mac that u had on computer card..
this in case ia have a static ip address and you need to make the internet connection with the provider... after that select from your pc network setting to obtain an ip address automatically ...and you put the sub-net mask at 255 255 255 0 and the default gateway as the ip address of the router ...
do not forget the router is now your connection with the provider so there is where you set the provider 's settings ...
if you have a modem too just select at the wlan in the router .to obtain an auto ip ...and in the computer too ..you may also clone the mac adress cause the provider may have it ..and block the acces cause didnt recognize the new one (router's Mac)
Jul 30, 2009 | Linksys WCG200 Wireless Router
Dns failed when i tried to setup xbox live. i have a belkin router set up and my console is set up next to the xbox. what do i need to do?
Information on setting up port forwarding can be found at:
http://portforward.com/
If you want to go with a static setting this is what you need to do:
  • Login to the Router/Gateway by entering it's IP address in your web browser. (http://192.168.2.1)
  • On the left panel of the firmware page, under "Firewall," you should see a link "DMZ" for the Static IP configuration.
  • Your router should generate 25-50 Dynamic IP addresses for, choose a Static IP outside that range. (192.168.x.200)
  • Then go into your Xbox network configuration and set the IP address to the newly defined DMZ.
  • IP: 192.168.x.200 Subnet: 255.255.255.0 Gateway: 192.168.2.1 (Primary DNS is the same as the gateway)
If you need more information about your router follow this link:
http://www.belkin.com/support/product/?lid=en&pid=F5D7230-4&scid=221
Mar 08, 2009 | Microsoft Xbox Console
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
No Internet connection
First of all I am interested to see the output of this on both machines:
Start->Run->CMD [Enter]
In the Black box type:
ipconfig [Enter]
I would like to see this information if you could be so kind.
You need to check your TCP/IP Settings to make sure they are both set to DHCP which will make it receive a Dynamic IP Address. Also it should set the gateway address for you but you may need to specify the correct addresses for IP, Subnet, Gateway and DNS to ensure immediate access to the internet. Most likely you are in this range but I could be wrong:
192.168.*.* IP
255.255.255.0 Sub
192.168.*.* Gateway
DNS Depends on your ISP but you can find out the information by logging into your router for instance:
http://192.168.1.1 will get you to your router if
your IP one of your clients is 192.168.1.*
Dec 10, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically
Oct 28, 2008 | Gateway Computers & Internet
IP settings
Yes it is but you'll have to get the Dynamic IP from a DHCP server or a router capable of doing DHCP. If you have one of these then all you need to do is:
Control Panel
Network Connections
Double Click on the network link your using
Properties
Under the Connection uses the Following Box Click
TCP/IP
Properties
Obtain an IP Address automatically
OK
and your done. This is for XP but Vistas pretty much the same with some slight differences
Like I said before though u'll need a DHCP source external to your PC to give you an address
Jul 27, 2008 | Gateway GT5408 PC Desktop
Xbox & nat
  1. The most likely problem is that your Pc IP is on different subnet try and change your pc to dynamic i.e Obtain IP address automatically.
Dec 30, 2007 | Arris SBG1000 Wireless Cable Modem Gateway...
U.S. Robotics USRobotics Wireless MAXg Range Extender USR5441 wireless network extender (S4466719) Logo
334 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
