Question about Garden
Toro z master model 74176 dies while mowing...will start right back up. What is the problem??
    Sergeant:
    Champion:
  • 250 Answers
You might have some water condensation in the fuel tank. Try putting some dry gas in the gas tank and see if it corrects the problem.
Posted on Mar 15, 2011
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
Toro wheel horse 14 38 hxl
check your wiers that go to you solinoid but first try to jump your mower usind jumper cables put the red cable on the bottom bolt of your solinoid and find a good ground for the black cable then let you car warm up then trun the key on your mower to start and it will start
May 12, 2013 | Toro Garden
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
I had a similar problem. I'll bet I took off the carb. 5 - 6 times and cleaned it with no success. Very fustrating! One time while checking the fuel level I accidently left off the gas cap, I started it and while running I put the gas cap back on and started to mow and about 10 seconds it died. I thought could'nt be! So I loosened the cap, restarted and it kept running. Any way the small vent hole was plugged. Thats my story!. Good luck.
Aug 20, 2010 | Toro Lawn Mower With Toro Power Tools
Hope this isn't a double post. Yardman push lawn mower rear bag starts right up and then mows about 6 rows before stopping. I start it again and it mows about a row and stalls. I let it sit for about an...
it sounds like you may have a vapor lock on your fuel tank   there should be a diaphragm on the inside of the fuel cap  that lets air in but not out   it may have an air hole clogged  take the cap apart if you can and clean it real good and put it back together   if that is not it  then the float in your tank may be stuck   or a fuel line filter may be clogged
Nov 07, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Tractor won't start, engine turns
best guess , blocked main jet or water in the carby
an overhaul would be in order
Oct 24, 2017 | Toro Lawn Mower With Toro Power Tools
Got a Craftsman 6.25 HP push mower. Had it for just over 2 years. I pulled it out of the garage to mow the grass the other day, and it would not start. I used some starting fluid and it started right up....
Check the fuel line for cracks or breaks. Check the fuel filter if it has one. And finally, you may need to disassemble the carburetor and spray with carb. cleaner.
Jim
Jun 07, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
