Question about APC (SUA3000I) UPS System
I need calibration step by step guide for SUA3000i.
Troubleshooting
It's not rollers. Try taking the glass guides out and cleaning them. Then calibrate. If that doesn't fix it then cleaning mirrors in cameras is next step.
Jan 31, 2014 | Kodak I610 Path-Through Scanner
This is a adress that is shown my treadmill model : http://www.diaplasi.gr/oxide/cf_9010.html.
please go under the HOOD motor and follow the steps for RUN the software calibration or go under the instr. manual and follow the steps how to enter the s. calibration.
tHIS will be guide to easy diagnose, troubleshooting, and fix it.
God bless you
Dec 13, 2012 | Exercise & Fitness
How can I calibrate the speed of the display to the speed of the belt?
You have two options:
1) Read Your owner manual, and follows the steps.
or
2) go under the hood, and read the follows step, for your calibration software.
3) The calibration software, will guide you to diagnostic and fix it.
sincerely. Happy New Year. G-d bless you.
ernesto cuadra
managua, nicaragua. c.a
Dec 27, 2011 | Horizon T92 Treadmill
How to calibrate speed on t92
1) Under the hood lift and see the instruction for use the software calibration, and follow the steps, and proceed.
2) This will guide you to diagnostic, and fix it various problem to factory settings.
sincerely. Happy New Year . G-d bless you.
ernesto cuaddra
Cannot get tony hawk big air shred board to calibrate
There is no need to have technical knowledge to do fix this problem.....Just get repair guide from internet and follow the steps in it and fix your problem by your own.......
Click here to download repair guide
Jan 05, 2011 | Nintendo Wii Console
Manual is not clear how to calibrate detector where can i get a further guide for whistler xtr -540
On the bottom of the unit there should be a sticker that calls out the steps to calibrate the compass.
Jan 02, 2011 | XTR540 Radar Detector
APC SmartUPS 3000VA
APC do not release cct diags and these are not easy to repair, if the battery fuse was open and there is some board damage, the thing is toast. Even if you get it going the battery will not be able to be calibrated, unless there the board/processor is 100%, I know this as we have a similar model on the bench right now with new batts in and the unit will not recalibrate, so even though the batts are new, as soon as the mains is dropped it goes to very low battery and shuts down in 2 mins.
Buy a new UPS save yourself a lot of time. Hope this helps
Thanks for using FixYA
Aug 02, 2010 | APC Smart-UPS 3000VA UPS System
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
I need to change an NCR 7875 - 2000 from lbs to kg Regards Peterm
Firstly you will need NCR Scan Tags. You can download from
http://ncrpr.ncr.com/web/rsdmkt/dealerReady/docs/User_Guides/HighPer_Scanner-User-Guide.pdf
You will have to print out the Scan Tags which start at page 281 and you will also need the correct weights; 0kg, 2.5kg, 5kg and 10kg.
Then follow these steps and be sure to scan tags in correct order:
1. Reset
2. Default
3. Program mode
4. Hex 3
5. Hex 0
6. Hex 1
7. Push the calibrate button under weighing tray
8. Place the correct weights in order. It will ask for the weights in order.
9. Calibration complete
Jun 05, 2009 | NCR 7875
APC (SUA3000I) UPS System Logo
159 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
