Question about EliteGroup 848P-A Motherboard
I have mercury motherboard and i am facing problem when i am start my pc system not start after two three time i will be tried but machin not start .when i am short system cmos pc will be start i am daly facing this problem can any budy help me hwo i swoled this problem
  • 731 Answers
Hi :) Did you try replacing the battery? on the board it should be a CR2032 3volt battery.
Posted on Mar 15, 2011
P4/not booting up upon start
Hi try to open you chase and unistall all the additional slot cards and try to boot up, sometimes one of the slot cards fails and if that happens your machine wont start up until that slot cart is removed, thats how your machine protects it self
May 08, 2009 | Intel D865GBF Motherboard
Mother board creates sound
It sounds as if you inserted the RAM while the machine was turned on? You may have damaged the RAM, support chips, or perhaps the power supply if contact was made where it shouldn't have been made.
Because some voltage is present even when the machine is turned off, you should either turn off the power with a switch on the back of the system, or pull the AC plug from the wall if no switch is present, before doing any insertion or removal of RAM or add-on cards.
Mar 09, 2009 | Mercury P4VM800M7 Motherboard
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
Dell start up
Two things to try that are common causes of this are; 1- remove the battery and start up on the adapter only, and 2- remove the memory and try each chip one at a time in each slot. If these do not work, then the problem is with a motherboard component, most likely in the power management system. If it is the power management system, then motherboard replacement is considerably cheaper than have the components repaired unless the machine is under warranty.
Aug 26, 2008 | Dell Latitude D600 Notebook
Mother board
Hi FRND,
You need to open the cabinet or PC system after that just have a look at the CMOS battery remove it and start the PC system for 5 to 15 second…
connect the Keyboard and mouse to the system have a look at the LED’s at the right hand side of the keyboard it it flash the power ok from the motherboard try using the replacing one by one … try replace keyboard & mouse might be short in side…
Jan 07, 2008 | Mercury P4VM800M7 Motherboard
Sytem Wont Start
Hi suisboy,
This sounds similar to a problem I had with a clients PC. The best way to debug this is to swap out one component at a time and see it it fixes your problem. However, if you can't do this then I'd suggest you try the following in this order.
  1. Remove all cards from the PCI bus leaving only the graphics card in place.
  2. Unplug all drive cables from the motherboard and power from the drives.
  3. Try to boot the motherboard. If successful try this, several time and if you don't have any problems you are okay to proceed.
  4. Enter the BIOS and load load the Default settings.
  5. Enter the BIOS and make it run the system check to fully test the memory.
  6. One by one re-attach your drives, if the system is stable continue to add you PCI cards until you hit the problem again. This will be the incompatible or faulty card.
This procedure should allow you to find the component that's causing your bus timing fault.
I hope this will help you diagnose your hardware.
Regards,
Spare head 2
Jan 06, 2008 | Mercury P4VM800M7 Motherboard
EliteGroup 848P-A Motherboard Logo
52 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
