I have a set of technics SB-5000a speakers. one of them the 10" sub is blown. there is no resistance accross it. the cone is in good shape so i think it is the driver. normally you can unscrew the driver, but in this case i don't think you can. so can i replace it or do i have to get new speakers?
  • 1,591 Answers
If there's NO resistance, see if the lead running to the cone (coil) has broken.
If so, you might be able to solder it back on and save the speaker.
Sometimes they separate at the terminals, sometimes at the cone.
If it separated at the cone, you may need to peel back a bit of paper to get to the wire underneath, and scrape the enamel coating off the wire so you can solder to it.
Otherwise, it's off to your local audio mart to buy a 10" whoofer at the same or higher wattage and same impedance. Take the old one with you to make sure the screw holes align too! (although that's not 100% essential as you can always drill new pilot holes wherever the screw holes aare....unless the screw holes have a metal insert)
If you did have to peel back some paper to do the repair, reinforce the torn area with toilet paper and fingernail polish. Use several layers as you don't want the movement of the whoofer to rip apart your solder joint or any more of the cone.
Posted on Mar 15, 2011
  • 3,400 Answers
You have to replace 10" sub as an assembly.
Kenwood 10 inch sub no sound on both of them
test the speakers on the + & - on the speakers if you get resistance they work if not then they don't. also check the wire from the cone is soldered to the connector. as they can come off and need resoldering back on.
Nov 11, 2013 | Car Audio & Video
Hi i have a bnps102 subwoofer system along with a pyle 1400 watt amp. my amp is getting power to it hence the green light lighting up and the subs sounded great but last week during a song they both...
You are right about the scratching sound meaning the speaker is blown. The other one by it not playing it could mean the voice coils in it are blown or burnt.The safest way to check the speaker is to connect it to a standard 9 volt battery and listen for a popping noise when you make the connection and look the see if the cone stands up as long as the connection is made n returns to normal and no noises when disconnected from the 9 volt battery. To test this while the sub is plugged in to the amp but out of the box move the cone as far in and as far out as it will go. If it comes on while u hold it on either one of these positions but when released it goes back to not playing then the coils in it are blown or burnt and is no longer any good. As for selling the box its on you, aim anywhere from 2/3 to 1/2 the price you paid for it minus the speakers.
Aug 22, 2011 | Pyramid Subwoofer Box Dual 10" 1000w ...
Hello there! I have an 8-10 yr old Bose Accoustimass 10 speaker system connected to an Onkyo TX-DS595 receiver. After moving and setting up my system the Bass Module has almost no base coming out although...
What is your crossover setting set at?
If it is set at 40 HZ, this would explain weak bass; as that Bose system sends ~120HZ down to the sub.
I reccomend checking the crossover setting to 120 or 100; with all speakers to small.
You may need to increase the db setting on your sub as well......
Good Luck.
Mar 24, 2011 | Audio Players & Recorders
I have just bought a technics sc-dv290 hi-fi off of my cousin and found out the mid range and the tweeters have blown does anyone know where i could get replacent tweeters and mid-range speakers for it if...
As you probably know, these are the individual model numbers:
SC-DV290 the base unit
SB-DV290 speaker set
Front SB-DV290
Center SB-PC95
Surround SB-PS95
I'd scour Google or eBay for any or all of those models. Orphan speakers appear periodically.
Feb 10, 2011 | Technics SC-DV290 System
One sub works other doesn't
Disconnect the wire from the speaker and meter it out. check it for a dead short, the meter would read 1..... You can also check the action of the sub by pushing on the center lightly, moving the cone. If it's blown, it will not travel smoothly. If your meter reads ......1 then you've really done it and totally cooked the wire clean thru, thus no resistance. Hope this helps.
Sep 29, 2009 | Xtant A3001 Car Audio Amplifier
Blown?
Typically you will hear a popping sound when the bass hits, or you may not have any sound at all.......If the sub sounds good then your ok.
On a side note, pulling on the cone while the sub is in operation can damage the unit because it cannot move freely under load
Sep 25, 2009 | Clarion SRR6923 Car Speaker
Blown solobaric?
how did he messed up? anyways, if u push the cone of the sub down and u hear a sound like "TUN!" its most likely ur sub is irremediably damaged. The cone needs to come up perfectly as a good sub would do. I need to know exactly what ur friend did b.c it is quite weird to mess a good sub by slightly switching cables
May 24, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Technics sax-710 receiver Nht sb-1 speaker developed a buzzing sound when playing, Kids may have over drove speakers(not sure) Replaced with nht supezeros now both speakers sound very staticy like off...
The speakers have buzzing sound because of damaged cones.
Over driving speakers, especially with heavy low frequencies, can tear the voice coil away from the cone.
Once damaged, only replacement will help
Apr 24, 2008 | Audio Players & Recorders
How to repair a blown sub
i have a problem, i dont think my speaker is blown, but , it just looks like the wiring broke on the coil at the end that connects to the cone, i think thats how i can best describe it..its a 10" pioneer IMPP w/ integrated voice coil cooling system 500w max and also it looks like where the wires broke, the coil cam unglued from the cone.. hope someone can help me..is this something i can repair on my own or is it garbage?
Jan 05, 2008 | Polk Audio db400 Coaxial Car Speaker
Help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Sep 07, 2007 | Panasonic SC-HT920 System
204 people viewed this question
 Grubhead
Grubhead
