Question about Briggs & Stratton Garden
I have a Briggs and Stratton Quantum XM 35 engine on a Hayter 51 mower. Can anyone tell me the torque settings for the cylinder head bolts? Thanks
5 Suggested Answers
  • 110 Answers
SOURCE: where can i get a manual for a briggs and stratton
You can download a manual for the engine from Briggs & Stratton's web site - you just need the numbers off the blower shroud. No manual exists for the actual mower.
Posted on Sep 22, 2009
tmandink
  • 30 Answers
SOURCE: What spark plug should be used for a Murray Quantum XNP 6.5hp mow
Home Depot has the plug you need for briggs 6.5hp engines. Don't worry about it being a Murray. Buy a Briggs 6.5hp plug.
Posted on Jun 26, 2009
  • 93 Answers
SOURCE: Cylinder head bolt torque setting for a
Search Briggs on the Web, You can order Manuals there. The torque is in in. pounds. Need more info ! A just get them tight and all about the same will work, stagger the bolts in the Head when tightening ( one bolt, one side then the other until done.) Then check them all.
Posted on Sep 15, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
Torque spec on 21 hp briggs and strattonand sequence
Doug, Torquing multiple bolts, like on a cylinder head are shown in last video link.Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
FAQ Small Engine Specifications Briggs Stratton Specs
Engine mounting pattern
HOW TO LOOK UP AND TORQUE BRIGGS HEAD
How to replace Briggs Stratton Intek Head Gasket Pt 2
Jun 01, 2016 | Cars & Trucks
What are the torques on a 22hp ohv briggs and stratton head and also push rods
VERIFY your engine model numbers
Briggs & Stratton Intek V-Twin
Engine Model Numbers 407777 and 44P777
Cylinders 2 (Dual cylinder)
ITEM N m (Newton metres) lb-in Spark Plug Torque 20 180 Back Plate (to cylinder) 11 100 Blower Housing Screws 9 80 Breather Screws 6 55 Carburetor to Manifold 7 65 Cylinder Head Bolts 25 220 Cylinder Shield 7 65 Crankcase Cover 23 200 Engine Mounting Bolts 48 35 lb-ft Electric Clutch Mounting Bolt 75 55 lb-ft Exhaust Manifold 16 140 Fan Retainer Bolts 16 140 Flywheel Nut 203 150 lb-ft Armature Mounting Screws 3 25 Intake Manifold Bolts 9 80 Rocker Arm Adjustment Lock Nut 7 62 Rocker Support Screws 11.3 100 Valve Cover Cap Screws 11 100 Carburetor to Intake 7 65 Valve Clearance (Cold) 0.10-0.13 mm (0.004-0.005 in)
WARNING: Uneven tightening will warp the head. Tighten Cylinder Head Bolts down evenly by hand. Then using torque wrench tighten in sequence, in 9 N m (80 lb-in) increments to 25 N m (220 lb-in).
Intake valve push rods are aluminum.
Exhaust valve push rods are steel.
DO NOT interchange push rods.
Removal and Re-installation sequence for bolt removal and tightening.
Mar 21, 2015 | Garden
I need cylinder head and magneto torque specifications
From what I found it has a Briggs and Stratton 98900 engine?
http://www.briggsandstratton.com/~/media/Frequently%20Asked%20Questions/Engine/PDFs/Engine%20Specifications%20Chart_ms3992.pdf
Oct 11, 2014 | Garden
Repairing a Briggs and Stratton Quantum 35 mower engine. How do you replace the metal starter pawls in an older Briggs & Stratton mower engine
take cap off drive the pin out the bottom from the top replace starter pawls and springs put back to gether drive the pin back in checking making sure not to thight if it is drive pin back some until it spins freely
Aug 22, 2014 | Garden
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Cylinder head bolt torque setting for a ''briggs and stratton 0252 engine
Apr 06, 2009 | Garden
Garden Logo
903 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
