Question about Dryers
Test test test 15.03.11 11:25 please do not touch
    Top Expert:
  • Dryers Master
  • 76,164 Answers
Do not touch what?
Posted on Mar 24, 2011
Treadmill blowing electrics when switched on
Step 1:
1) please use desk lamp and connect in outlet wall, where the treadmill is connected.
2) if the breaker or fuse is blown, the problem is the outlet wall.
3) Test the wire ground with DVOM, if there are touching with another wires inside of the outlet
4) test the another wires white + black, if there are touching, or there connecting with the carcase from the outlet and repair.
Step 2:
1) if the problem if the machine: please test the power cord use the DVOM for continuity
see the video for measure continuity
2) test the main switch from treadmill
3) test the reset switch for continuity
4) test the fuse +c.breaker for faulty with contunuity and repair
5) test the power supply continuit see the block diagram
Step 3:
please test the main motor for open or faulty see my personal TIPS for motor help.
2) test the output main board , for input voltage motor, if there are NOT the board is faulty,replace the boaatd use the DVOM for measure Voltage.
use the diagram above mentioned.
Jan 07, 2013 | Exercise & Fitness
F1 error code
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Mar 04, 2012 | Kitchen Ranges
F1 error code
present.
the ERC (Clock).
repair technician.
panel.
sound).
touch pad.
Feb 26, 2011 | GE Profile JKP56 Electric Double Oven
F1 error keeps beeping loudly
F1
Note: Some models
Warning: If
1. Disconnect
2. Gain
on.
Jan 19, 2011 | GE JTP15 Electric Single Oven
What dose f1 mean
(Clock).
Dec 12, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
When I press bake and start it beeps and gives me a code of F1, can you please help me figure out how to fix the F1 so I can have an oven?
Nov 25, 2010 | Whirlpool RBS305PDS Electric Single Oven
F1 ERROR CODE
Nov 22, 2010 | Maytag CWG3100A Gas Single Oven
I am receiving the same error message on the display window
Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Function key shorted or stuck :
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Sep 12, 2009 | Maytag MER6769 Gemini Electric Kitchen...
The Alarm keeps buzzing to my Jenn Air ww2780w wall oven. The code reads F1. What can I do to fix?
You can use the test procedure below to narrow the actual issue.
Jul 09, 2009 | Ovens
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
