Question about Cameras
My everon digital camera show the lock option during capturing a videos or taking a picture it show that my camera is lock. and the protection options are disabled and can't enable.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Mar 15, 2011
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Camera won't take pictures it show protected card
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 23, 2014 | FUJIFILM A220 Digital Camera
Card locked shows of view finder, cannot take a picture it shows a't picture but won't take a picture
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 06, 2012 | Canon PowerShot S2 IS Digital Camera
When i use the camera it shows the is card lock and in camera there is no security option . i can't capture the photo
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 08, 2012 | Casio Exilim EX-Z77 Digital Camera
When I try to delete a picture/video it says WRITE PROTECT with a ! point
Hi there, Can you take pictures on it? It sounds like the SD card is locked. If you take the SD card out, you should see a slider on one of the sides. Push it up to unlock the card - then you should be able to delete. If it is already up, then there is a write protect option on your camera you need to disable. Alex
Jun 04, 2011 | Olympus Stylus Stylus 820 µ Digital 820...
Every time I go into capture or video mode the key icon shows and I can't take picture nor record videos
I think the key is telling you that the video card is locked/ write protected. Assuming its an SD card. Take it out of the camera and look at the left hand side, there should be a notch that you can slide up and down, move it to unlock. If the notch is broken, cover it with a small piece of tape. Rather like we used to with cassette and VCR tapes.
If its not the card, then you may have photo/file protection switched in on your camera, you'll have to go throught the menu settings.
Oct 13, 2010 | Cameras
CANNOT TAKE PICTURES SHOWING PROTECTED CARD
Nov 12, 2009 | Fuji FinePix J10 Digital Camera
Protected pictures
you have to unprotect them first... sometimes if you juts format the card (insert into your PC) this will delete protected files as well..
Sep 27, 2007 | Samsung Digimax S630 Digital Camera
Protected feature
There are 2 probable solutions. 1. The images are "protected" by the camera & will show "locked" when you try to erase them. 2. The SD card in the camera is locked. The solution to 1 is to unlock the images in the playback menu. See page 46 of the manual. Note that you need to select "unlock" you can't select protect as they are already protected! Solution 2 is to remove the card from the camera & check the "lock" slider that you can see on the side (although no all cards have this). Set the lock off. You can download the manual from the first link on the following page: http://www.vivitar.com/manuals/english/ViviCam6300/CameraManual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 11, 2007 | Vivitar ViviCam 6330s Digital Camera
LCD screen displays menu items but will not display picture capture & won't take pictures
A very common problem with many Digital cameras. It sounds as if you are suffering from either a CCD problem or a video board problem. Impossible to tell without it being on the bench to check. You could dismantle it and check there's nothing adrift such as flat ribbon cables in their sockets or loose plugs and sockets between the printed circuit boards. Watch out for the flash unit it can give you a nasty shock if it's charged. Most cameras seem to built to last as long as the warranty and then die. This keeps you coming back for more. At least you were lucky to get 2 years out of yours before it passed on.
Jul 12, 2006 | HP Photosmart M307 Digital Camera
Cameras Logo
52 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
