Question about Siemens Washing Machines
Siemens E1244 Washing Machine Detergent Drawer is still full of water, once the wash has finished its cycle. Machine is only 4 Years old. I have already cleaned out the drawer, cleaned the filter on the detergent solution pump and cleaned the filter, on the water supply pipe, but the fault still exists. Any other ideas for me to try? Kind Regards Stuart Mayo stuart.mayo@hotmail.co.uk
  • 641 Answers
SOURCE: gunge
You can scrub it off with sanitizer. It is recommended to use gloves for it. Good luck !!
Posted on Jun 20, 2006
SOURCE: detergent drawer
Sorry I can't respond to questions under the header "'Generic Problem for all washing machines" because the focus it is too broad.
Posted on Jan 26, 2008
MNTECH
  • 1543 Answers
SOURCE: Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Posted on Oct 11, 2008
barkencoa
  • 3463 Answers
SOURCE: the fabric softener drawer is
Remove drawer and thoroughly clean, you must have a blockage in it for the water to remain.
Make sure that you clean every piece of it, taking all the components out.
Please leave feedback.
Posted on Dec 01, 2008
SOURCE: front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Posted on Jun 16, 2009
Maytag 1200 AAW front loading washing machine
What do you mean additive? There are 3 compartments, one for bleach, one for detergent and one for the softener. Which one is it?
Jan 17, 2014 | Washing Machines
Siemens E1244 Washing Machine Detergent Drawer is still full of water, once the wash has finished its cycle. Machine is only 4 Years old. I have already cleaned out the drawer, cleaned the filter on the...
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 15, 2011 | Siemens Washing Machines
Fabric conditioner section in draw always full with water after cycle has finished
Detergent drawer is clogged with soap. to remove look for small plastic clip on the inside above the detergent drawer which needs to be released. Remove detergent drawer unit and wash thoroughly under running water, or bucket. Replace and problem should be solved until it gets clogged again.
Jan 15, 2011 | Bosch Classixx WFC 2465 Front Load Washer
Machine won't draw out fabric conditioner from dispenser
I dont know what model you have but you are correct in your assumption that the conditioner is siphoned out on the last rinse unless it is different for your model.Most machines I am familiar with operate in the first instance.Check that you have good water pressure to all compartments also get a toothbrush and clean the holes above the drawer even a bent piece of wire to unblock the small holes.
Good luck
Apr 12, 2010 | Washing Machines
Horrible smell coming from the washing machine
Have you cleaned the filter in the washing machine?
Mar 31, 2009 | AEG 24 in. Favorit 40660i Built-in...
The fabric softener drawer is half full of water which does not drain away, even after the washing machine has finished. The detergent drawer is fine. how can I drain this water away? Kind...
Nov 30, 2008 | Siemens WM5487A Front Load Washer
Water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
Nov 24, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Detergent & Conditioner Drawer
Perhaps it needs to be thoroughly cleaned out first - sometimes the gloopy mess collects and blocks the outlet hole.
Oct 30, 2007 | Neff W4380X1 Front Load Washer
Leaking water
Possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine. Also use only detergent for 'front loading machines'.
Oct 07, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
124 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
